Quick synthetic oil question
Old Dec 31, 2006 | 11:27 AM
Alwyn678's Avatar
Alwyn678
Default Quick synthetic oil question
Does Synthetic oil help All engines or only engines that are "NEWER" or have used it since NEW?
Old Dec 31, 2006 | 12:18 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You can use it in any engine. I converted my '76 to synthetic about 10 years ago and all has been fine. Some will say that changing to synthetic after running mineral oil will tend to produce some oil leakage around gasketed areas. Some say synthetic is not worth the money. This subject has been discussed for years and will probably continue to be. Everyone has their opinions on the matter. I personally run synthetic in everything I own including my lawn equipment and have never had to take an engine apart, some of which have over 200k miles on them.
Old Dec 31, 2006 | 12:20 PM
Fevre's Avatar
Fevre
Oil lasts longer and is better IMHO but you still need to change your filter regularly, just add oil to make up for the oil in the filter
Old Dec 31, 2006 | 12:28 PM
Alwyn678's Avatar
Alwyn678
Thank Jud, that is what I wanted to hear. Is Mobil a good brand or are they pretty similar...............Did you have many oil Leaks?
Old Dec 31, 2006 | 12:56 PM
Big2Bird's Avatar
Big2Bird
What kind of cam and heads you running in that lawn mower?
Old Dec 31, 2006 | 01:38 PM
Abbacabba's Avatar
Abbacabba
There have been a small number of "scientific" type tests done on conventional vs. synthetic. I've seen them mostly in magazines like CHP or muscle car.
I believe that its usually in the range of 2-5hp lost/gained.
I've also heard the rumors that switching to synthetic can produce leaks. I doubt this, but I have seen synthetics make a leak worse, most likely because the synthetics have cleaned out the area of old gunk.
I've heard this suggested by others also and I did notice that my first few changes -after- switching the oil came out much dirtier(perhaps it was doing a better job removing old contaminated residue?)
I've run synthetics in my past few vehicles and noticed that they are noticeably cleaner at changes than conventional mineral oils.
I've used Mobil1 and Royal Purple and never had a problem. Plus you can run them longer and you don't have to worry too much about times when your engine temp gets a little high.
Old Dec 31, 2006 | 02:24 PM
jerrylee's Avatar
jerrylee
Default Synthetic...
How soon after engine break-in may I switch...I did a total rebuild n just hit 1,000 miles n my Redline is waiting....Jerrylee///
Old Dec 31, 2006 | 02:40 PM
Jud Chapin's Avatar
Jud Chapin
I use Mobil 1 and can't really say about my gaskets as I coincidently changed most around the same time.
Old Dec 31, 2006 | 02:44 PM
Jud Chapin's Avatar
Jud Chapin
You might want to talk to Redline about this. You know many new cars including Vettes come with synthetic. I don't know how they get around the break-in period. Perhaps someone can help me with that.
Old Dec 31, 2006 | 02:48 PM
Jud Chapin's Avatar
Jud Chapin
You're a riot Alice! (Ralph Kramden to his wife on "The Honeymooners" TV show). Catch the reruns if you've never seen it.
Old Dec 31, 2006 | 02:51 PM
Jud Chapin's Avatar
Jud Chapin
BTW Alwyn, beautiful car you've got there.
63mako's Avatar
63mako
St. Jude Donor '08-'09
Make sure your rings are seated then change to synthetic. A leakdown test would be nice to make sure everything is seated. Some rings seat at 100 miles, some at 2000 miles depending on the rings and honing finish of the cylinder.
Old Dec 31, 2006 | 06:20 PM
Alwyn678's Avatar
Alwyn678
Thank You kindly!!! Your car is Beautiful as well!! That yellow looks Great on the Vette!!
To Quick synthetic oil question
