Seat Belts
Old Jan 1, 2007 | 04:19 PM
billsfan's Avatar
billsfan
Default Seat Belts
I am looking for new 3-point seat belts. Wesco performance has 2 sizes, 120" and 140". Should I get the 120" ? Their price is around $140/set. Are there any other good options? I've heard people use camaro reat belts, but they probably come with the floppy end for a bench seat. By the way, I have the original belts, but they won't work since Bubba has already welded up the retractor compartment under the seats!
Old Jan 1, 2007 | 05:37 PM
Durango_Boy's Avatar
Durango_Boy
If he just welded the pocket shut on the top, just use a grinder and cut out the plate. Don't let Bubba muck up your seatbelt plan.
Unless you're a very girthy guy, the 120" should be fine.
Old Jan 1, 2007 | 07:48 PM
billsfan's Avatar
billsfan
The original compartment rusted through, so it is gone. I suppose I could fabricate a new compartment. I really don't want to put in new pans. I think I'll just go with the 120" 3-point. Thanks. By the way, the original belts work fine, they just have rust around the retractors. Maybe I could sell them to pay for the new ones?
Old Jan 1, 2007 | 10:59 PM
Durango_Boy
So long as you have access to some metal tools, you can make a pocket by cutting and bending a sheet of S/S into new pocket, and dropping it through a cutout. Maybe not pretty but it will work. Then either weld it or rivet it in place tot eh existing floor pans.
Old Jan 1, 2007 | 11:09 PM
GruntyPants's Avatar
GruntyPants
Hey BillsFan,
If you get the full set of seatbelts from a newer Firebird or Camaro, You can mix and match the set. Use the retractors from the rear seats and the rigid receivers for the front seats. I put a set in my '69 and love them. I had to make up some new brackets for the rear, but overall very worthwhile.
Old Jan 1, 2007 | 11:18 PM
Durango_Boy
Originally Posted by GruntyPants
Hey BillsFan,
Can you walk me through that again? More details? I want to get a set of Camaro/Firebird belts, but I'm not even sure which ones to get, and how to mount...or mix and match with the stock stuff. Thanks for the extra details.
Old Jan 2, 2007 | 06:45 AM
redwingvette's Avatar
redwingvette
I have the F-body seatbelts in mine. I used the original plastic sleeve off the old ones to make mine ridged.
seatbelt install
Old Jan 2, 2007 | 10:17 AM
GruntyPants
Durango,
I think mine were from a '93 Firebird (That's what I was told anyway). I'll take some better pictures today when I get home. My biggest problem was that the retractors on the wheelwells had to be mounted 90* from the originals so the locking mechanism would work properly, and I had to make some brackets.
Old Jan 2, 2007 | 10:19 AM
Durango_Boy
Durango,
That makes sense. I'll look forward to those pics. Thanks so much.
Old Jan 2, 2007 | 10:34 AM
genuine1980's Avatar
genuine1980
What year corvette do you have the original belts for?
Old Jan 2, 2007 | 11:10 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Matt, after 69 the seat belt mounts were on top of the fender wells. You should not need any brackets to fit the Camaro belts in your car. The biggest hurdle is the rear seat belt connections do not fit into the front seat belt connections. As I used to have an upholstery shop, I still have a comercial sewing machine. I was able to switch the rear belt female ends for the front belt ends to get them to work. then all of the plastic supports can be used to hold things in place. I even went a step further and switched male and female buckles for a set from a Caprice to get the GM logo on the buckles. The Camaro buckles are so generic looking IMHO. I have a complete set of Camaro belts available if someone is looking for a set. PM me for a pic.
Old Jan 2, 2007 | 11:28 AM
gyopp's Avatar
gyopp
I used a retro 3point seatbelt kit from Ecklers that is pretty much a bolt in replacement for late C3's. It only uses 1 retractor by the rear wheelwell mount. They fit and look great for a lot less $$ than having OEM belts refurbished.
Old Jan 2, 2007 | 04:37 PM
billsfan's Avatar
billsfan
Hey BillsFan,
Thanks for the info. A complete used Camaro set is cheaper than a new corvette set!
Old Jan 2, 2007 | 04:39 PM
billsfan's Avatar
billsfan
The belts are black from a '76. Some rust on the retractor frames, the belts look good and work, chrome is hardly pitted
Old Jan 2, 2007 | 05:10 PM
Durango_Boy
Got a part number handy? I was gonna do a 3-point using late model Camaro belts, and nix the under-seat retractor.
Old Jan 2, 2007 | 08:16 PM
Phlash's Avatar
Phlash
The rear belts out of an Oldmobile Aurora fit the original corvette buckle next to the console. The spade is the same size as the original. I found this to be a better fit than the F-body belts.
Phlash 72 BB Roadster
Old Jan 2, 2007 | 10:52 PM
gyopp's Avatar
gyopp
Here is the link to the Ecklers units
http://www.ecklers.com/product.asp?p...dept%5Fid=1707
$259 car set
To Seat Belts
Old Jan 2, 2007 | 11:31 PM
68RATVT's Avatar
68RATVT
$259 car set
Cool, thank's for the heads up, been looking at options.
Old Jan 3, 2007 | 07:01 PM
Durango_Boy
What years of Aurora cars? They had two or three different models I think.
Old Jan 3, 2007 | 09:24 PM
Phlash's Avatar
Phlash
It was a 1995. The rear belt retractors mount high on the rear window shelf in the Aurora, which fits nicely on the rear wheel inner fender mount in the vette. I used these so I didn't have to change out the original buckle next to the console in the vette.
Hope you find some,
