Frame supports
Old Jan 2, 2007 | 05:05 PM
Merlinhaggard's Avatar
Merlinhaggard
Default Frame supports
The guy I bought this 68 from said it had been raced before he got it and the previous owner welded in some frame supports under the doors. Does anyone see anything here?. ??.
Old Jan 2, 2007 | 05:45 PM
ShinodaVette's Avatar
ShinodaVette
It looks like there is extra metal welded under the frame along the frame rail. Those welds aren't factory welds; looks like maybe some extra metal tacked to the bottom.
Old Jan 2, 2007 | 05:54 PM
Merlinhaggard
Hmmm..I see what your saying..
Old Jan 2, 2007 | 06:58 PM
84rzv500r's Avatar
84rzv500r
patch for rust....
Old Jan 2, 2007 | 07:01 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, I suspect the same thing, can you snap a closer shot of that hole in the triangular gusset? looks rusty up there
Old Jan 2, 2007 | 07:06 PM
84rzv500r's Avatar
84rzv500r
My frame was perfect except for that area... It looked ok but I went over the whole frame with a small hammer looking for thin spots... the section at the bottom of the kick ups was paper thin.... I cut it out with plasma and welded new frame pieces in.
Old Jan 2, 2007 | 09:54 PM
72LS1Vette's Avatar
72LS1Vette
That frame doesn't look to me like it is rusty enough to need a thick piece welded onto the bottom, and I don't see a lot of pitting, but some close-up pics of the kickup area would give more info. The holes that I can see look well defined and I don't see pieces of scale hanging out anywhere. That piece welded onto the bottom of the frame did block some drain holes though which could be a problem in itself.
As an example, this is what a rusty frame looks like:
Rick B.
Old Jan 2, 2007 | 11:42 PM
68RATVT's Avatar
68RATVT
I had a buddy with a 75,the previous owner welded twist point supports,told him it was a old school upgrade. There was no rust on his car, no reason not to believe him.....I had never heard of that, but I'm not an expert, old hot rodders did know a thing or two..
Old Jan 2, 2007 | 11:53 PM
big_G's Avatar
big_G
That's a '68, no metal floor-boards. Not a rust patch. Looks like they tied the front and rear seat track reinforcements together. Maybe the driver was a little on the hefty side. A poor job at that. But, the frame rail is patched over...suspect rusted section under that plate.
Old Jan 3, 2007 | 02:55 AM
Twin_Turbo's Avatar
Twin_Turbo
we were talking about the frame, didn't even notice the channel connecting the fr & rr seat bolt hole...but now that you mention it
Old Jan 3, 2007 | 07:38 AM
Merlinhaggard
I dont get it.. Does anyone have a pic?...I can compare with?.
To Frame supports
