SB Head 3946813
Valves 1.72/1.50
76cc combustion chamber
runner capacity unknown
Help
Hope this helps.
Hope this helps.
I am still at ground zero need to substantiate the valve, combustion and runner sizing. Someone out there has a reference that will shed some light on this subject. I believe the members of this forum have a great deal of knowledge.
it looks like you've tapped out the internet resources for a quick answer.
Not trying to be a SA here but none of the posts say if the head is on or off the motor. If the head is off the motor you can just measure the valves.
Other clues that may help identify it are:
The data code.
The casting symbol.
Drilled for a temperature sending unit
Pressed or screw in studs.
Drilled for a tapered spark plug or a flat spark plug.
Drilled for alternator mounting brackets.
The data code.
The casting symbol.
Flat spark plugs = 1969 and earlier
Tapered spark plugs = 1970 and later.
No temperature sending unit = 1967 and ealier.
Temperature sending unit = 1968 and later.
No accessory holes = 1968 and earlier
Accessory holes = 1969 and later.
You heads conflict with the accessory holes and sending unit information in the book. It may be that those heads were originally intended for a marine application which did not necessarily follow the car and truck applications.
If the heads were fitted with screw in studs from the factory, the motor probably had a high lift camshaft (mechanical). And high lift camshafts were generally associated with higher compression heads and the larger valves.
You may be pleasantly supprised when you find out how those heads are configured.
Good Luck
Hans
No listing of it in Corvette by the Numbers. Anyone have the book "Chevrolet by the Numbers", should be in there.
