Stock TH350 Speedo gear
Old Jan 2, 2007 | 05:27 PM
JustinD's Avatar
JustinD
Default Stock TH350 Speedo gear
What is the number of teeth on the stock drive gear for the speedometer cable?
Old Jan 2, 2007 | 06:56 PM
Duke94's Avatar
Duke94
I assume it's for your Pace Car. Depends on what axle you have. See upper chart (1978) not the lower one that is marked up (1979).
Old Jan 2, 2007 | 10:31 PM
JustinD's Avatar
JustinD
So with 3.08's I have a 8 tooth pinion and 19 tooth spur. Thanks that helps a lot.
Old Jan 2, 2007 | 11:32 PM
JustinD's Avatar
JustinD
Hum well if I'm going with 4.10 or 4.11's do you have any idea of what spur (driven) gear I would need?
Old Jan 3, 2007 | 06:41 PM
Duke94's Avatar
Duke94
Not for a TH350. My parts book shows 4 speeds and TH400 with 4:10 axles. The part numbers are different than TH350. I can email what I have and you can see if you can figure it out based on drive gear and driven gear teeth. PM me your email address if you want it.
To Stock TH350 Speedo gear
