EGR Vacuum Control Switch
Old Jan 2, 2007 | 10:05 PM
DO2G's Avatar
DO2G
Default EGR Vacuum Control Switch
I am installing an edelbrock 2101 intake manifold. I got rid of the AIR smog equipment and the EGR.
Do I need the purple top EGR vacuum control switch anymore?
Old Jan 3, 2007 | 12:32 PM
78vettespender's Avatar
78vettespender
No, I'm going through the same process now. You can leave the switch or remove it and replace with a pipe plug.
Old Jan 3, 2007 | 04:04 PM
DO2G's Avatar
DO2G
What did you do with the EFE TVS (green connector in top of thermostat)? Do I need to keep that?
I don't have the heater core hooked up anymore either and there is a heater hose that runs from the passeneger side of the intake to the water pump.
Old Jan 5, 2007 | 12:43 AM
78vettespender
I didn't have the EFE to begin with, I have a plug where you're talking about. I'm familiar with the hose to the heater core and water pump, but not sure why you'd disconnect that, heater core bad?
Old Jan 5, 2007 | 07:04 AM
DO2G's Avatar
DO2G
I never use the heat and it eliminates some cluttter.
To EGR Vacuum Control Switch
