broke rocker stud
Old Jan 2, 2007 | 10:09 PM
dmaaero's Avatar
dmaaero
Default broke rocker stud
on my 74 i had a rocker stud break today looks like someone before me put a single nut on one instead of an adjustiable cap should i upgrade studs or just get another set from chevrolet i'm not up to date on rocker studs it has double springs and a different cam i asume these are hydralic lifters but dont know how to tell i did a search and found how to adjust them if there hyd need a little help here thanks guys
Old Jan 2, 2007 | 10:26 PM
Ironcross's Avatar
Ironcross
Unfortunately they are not screw in studs. The missing posi-lock is probably down in the pan out of harms way. I have seen this before from tightning them too tight and actually streching the threads to a point they finally fail. Another reason some aftermarket stuff just dont work as good as the General originally made them. If thats a press in stud the head should probably come off as trash trying to repair the head will be all over to get the other 1/2 of the stud out. Just buy long slot stamped rockers next time. Thats all thats on L88`s!
Old Jan 2, 2007 | 10:39 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
with ironcross.
It looks like you have been making other mod to the engine, so it's time to step up the heads. If one broke due to someone over tightening it figure the odds that the other 15 were done properly. Cheapest way might be to find a set of Vortecs & a Vortec intake. I don't know the specs on your engine, you'll need to know that before buying new heads. The other path, if you are happy with the current performance level, would be to pull the rocker studs & have the heads machined for screw-ins, but that is kind of a waste on stock heads of little value anyway.
Old Jan 2, 2007 | 11:19 PM
dmaaero's Avatar
dmaaero
i have the posi lock it wont fit through the oil holes in the head i sat the rocker back on the stud and looks like i might have enough threads to put on a locking nut maby i could try that? looks like what someone did 2 studs over from the one that broke but that stud doesent look broke maby they just lost a posi lock lol if i try and unscrew the stud i will mess up the threads probly, i only had this car 3 weeks and i was impressed with the power i would like to know whats inside i just didnt want to find out quiet this quick
Old Jan 2, 2007 | 11:34 PM
Vette Crazzy's Avatar
Vette Crazzy
they make a tool to pull the rest of the stud out while leaving the heads on the car. pull the stud, and loctite the new 1 and press it in. something else to think about if you don't want to pull the heads off. you can drill thru the casting around the stud and straight thru the stud and out the other side and put a pin thru it. takes lots of time and patience. good luck
vc
Old Jan 3, 2007 | 09:26 AM
kevinator80's Avatar
kevinator80
Vette crazzy is right. Matter of fact, bobs77vet replaced one with a screw in and posted a very good thread last summer. Try searching his threads for more info.
Old Jan 3, 2007 | 09:50 AM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
If you turn this engine very hard at all, most likley this will happen again. The stock studs just will not take that much. The fix for that is to remove the heads and have your favorite machine shop put in 7/16 th screw in studs. Yeah its a lot of work to do that, but if it does happen again, you might break the pushrod, bend valves, ect. Valve train is no where to skimp on parts in a motor that you want to run hard and live long.
Old Jan 3, 2007 | 10:03 AM
Wrencher's Avatar
Wrencher
vc
This is correct. I have both the puller and installer, both of which are readily available. There must be some threads left to use the puller. Most of the other posts are right in that you've probably reached the limit of the stock press-in studs capability, but you could probably get away with just replacing it. Better yet, do them all and know that at least you have known good studs. These can be changed in the car, but make sure you drain the coolant and re-seal the new studs since the tapered holes go through to the water jacket. Congrats on the new vette, and how about a picture?
Hans
Old Jan 3, 2007 | 10:29 AM
dmaaero's Avatar
dmaaero
i tried to turn the stud (just in case it screwed in) it rung right off brittle as can be!!! what exactly do i need to know before i can get new heads ?
Old Jan 3, 2007 | 11:00 AM
GUSTO14's Avatar
GUSTO14
David, sent you a PM...
GUSTO
Old Jan 3, 2007 | 03:57 PM
dmaaero's Avatar
dmaaero
wrencher i got you a picture does anyone know what these are ? my plans right now are to go back with screw in studs in the original heads but i'll look around tonight an see what other heads i can find if those are stock 1974 pistons cant i use about any head i want to?
Old Jan 3, 2007 | 05:26 PM
Scott Marzahl's Avatar
Scott Marzahl
Yeah, they are TRW hypereutechtic pistons, .030" over with a .125" dome.
Old Jan 5, 2007 | 09:04 AM
dmaaero's Avatar
dmaaero
well i went to the machine shop wouldnt have been to bad just to replace studs but i have some other issues to the tune of broke inner valve springs new studs guide plates valve springs and a valve job comes to around 360-380 to much for these old heads thats allmost half the price of a set of dart heads so i'll get the darts i got my cam out i'll need some help iditifing that but this close i figure i might as well find out what bubba did in the bottom end while i'm at it the numbers on my cam are
engraved in the rear of cam 692130
next to gear 1517
between lobes cwc
between lobes e8
between lobes d1
and i really do appericate you gentlemen helping me with this david
To broke rocker stud
