Bleeding C3 Brakes
Old Jan 3, 2007 | 01:47 PM
TERRY CLARK's Avatar
TERRY CLARK
Default Bleeding C3 Brakes
I've worked on a lot of Chevrolet brakes but not Corvette. Do you bleed all 3 bleeders on each caliper?
Old Jan 3, 2007 | 02:04 PM
Hvymtlc5's Avatar
Hvymtlc5
here is some good info: http://iotech.no/corvette/technical/corvette_brakes.htm
Old Jan 3, 2007 | 03:13 PM
69autoXr's Avatar
69autoXr
There should only be two bleeders on the rears, at the top. The third hole at the bottom should just be plugged, bleeding here won't do anything except waste fluid.
The fronts only have one bleeder each.
Old Jan 3, 2007 | 03:16 PM
c3andc5's Avatar
c3andc5
Just did mine this weekend. Bleed the inside on the rears first, then the outside.
Old Jan 3, 2007 | 03:27 PM
Glassbowtie77's Avatar
Glassbowtie77
Left inside
Left outside
Right inside
Right outside
Left front
Right front
Old Jan 3, 2007 | 03:47 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Use a pressure bleeder, bang on the calipers to free bubbles and go around the car a couple of times...
Old Jan 3, 2007 | 04:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I like my My-T-Vac.
To Bleeding C3 Brakes
