Forced induction question.....
Old Jan 4, 2007 | 12:38 PM
hensen1954's Avatar
hensen1954
Default Forced induction question.....
If any of the turbo, etc boys out there know...
How much pressure / forced induction does it take for you to notice the difference - not melt the tyres - just notice the difference.
For example - if you took a totally stock used engine - smog or otherwise, you might get some extra bhp with a tune up and maybe a bit of cold ram air.......possibly 10 to 20 bhp. And you would notice that - I should think - it would have more "sparkle "
My question is, with no tune up or any other mod, how much forced induction would it take to create the same amount of sparkle.......I am guessing less than half a psi - am I in the ball park ???
Next question, if you did all the typical mods, heads, headers, manifold etc, and maybe get 100 / 150 / 200 bhp extra, how much forced induction would it take on the same standard engine to gain an equal amount of BHP......once again, as a total guess, I am thinking 12 to 18 psi - am I anywhere near ??
Old Jan 4, 2007 | 01:39 PM
big_G's Avatar
big_G
In my learning process, doing a supercharged build myself I have seen a general formula that when you double the atmospheric pressure (approx. 15 psi) to 30 psi (15 lbs. boost) you double the n/a horsepower. Another simplistic formula I have seen used is at 15 lbs. of boost: cubic inches X 2 = H.P....FWIW
Old Jan 4, 2007 | 01:42 PM
1970-Bronze's Avatar
1970-Bronze
On my SC Truck, every pound of boost is good for about 20 hp.
Considering drive train losses - I'd say 2-3 pounds of boost to actually notice the difference.
Old Jan 4, 2007 | 01:49 PM
big_G's Avatar
big_G
Also, keep in mind that if you drop the compression for your boosted application, the first few pounds of boost will only get you back to where you would have been with an optimized high compression engine. After 2 or 3 lbs. of boost, it's all gravy.
Old Jan 4, 2007 | 01:53 PM
Twin_Turbo's Avatar
Twin_Turbo
and also realize that boost is just a measurement of cramming air flow through a restriction, in this case the supercharger cramming air into the engine w/ the intake path being the restriction. This means that if you have a comparo between 2 engines where 1 is identical but the intake is restrictive, this engine will show higher boost levels for same compr. output, a hotter intake charge and lower power.
Old Jan 4, 2007 | 01:54 PM
bashcraft's Avatar
bashcraft
It will get you back to the original compression, but the air/fuel charge will be larger, which in itself will make the engine run as if it were larger.
Old Jan 4, 2007 | 01:58 PM
big_G's Avatar
big_G
Yes, that's why it is better to run more boost and a lower static c.r. than a less boost with a high static c.r..
Old Jan 4, 2007 | 02:16 PM
bashcraft's Avatar
bashcraft
The last blower motor I built had a static compression ratio of 5.6-1. I was able to run 25 lbs. boost with an 8-71 blower on a 427.
Old Jan 4, 2007 | 03:13 PM
hensen1954's Avatar
hensen1954
So, nobody knows then ..........
Old Jan 4, 2007 | 03:45 PM
bashcraft's Avatar
bashcraft
Why would anybody here care? After all, the point of forced induction, at least to us, is to get the maximum amount of power possible. Just equalling something else is not the intention.
Old Jan 4, 2007 | 04:11 PM
hensen1954's Avatar
hensen1954
Was seeking accurate knowledge - not intentions..........
And, if you take it a little further - depending on the maths involved.......
if you are seeking as much power as a C3 can handle without a terrific rebuild ( which is about 500 to 700 bhp ) after that you need brakes, diff etc,.. possibly there is a cross-over point when it becomes more cost effective and time effective to force induction the crap out of an un -modified engine rather than force induction a big buck engine.
Have come across this with a certain 4 cylinder euro engine, where you can turbo the crap out of it to produce about 600 ponies ....and it will not last more than about 20k road miles. BUT as a replacement engine from the breakers is only about 150 bucks, just do it again, and again, etc.
Old Jan 4, 2007 | 04:15 PM
big_G's Avatar
big_G
Way too many variables. For instance: I called Lunati, Comp Cams and Crane on cam selection for my Pro-Charger build-up. I told them my target was approx. 750 h.p. @ 6,500 rpm. One suggested 256/260 @ .050, the next said 230/236 @ .050, the last said keep what you have now (242/248@.050). Guessing what power you get for a given boost without much more data to crunch is futile, IMO.
Old Jan 4, 2007 | 04:38 PM
Pusher's Avatar
Pusher
I'm no expert, but you would need more data than just PSI. You need to no what volume; a large "roots type" super charger uses less PSI and more Volume, and the Turbo is the opposite, more PSI and less Volume.
If the information I've given is incorrect please disregard as it's what I was told by a engine builder.
Old Jan 4, 2007 | 04:44 PM
Twin_Turbo's Avatar
Twin_Turbo
the diff between a roots blower and a superchargre is that the roots is just an air pump, it has no internal compression.
To Forced induction question.....
