I Need Your Help
Old Jan 5, 2007 | 09:16 AM
rj8806's Avatar
rj8806
Default I Need Your Help
Hello everyone:
I hoping someone can help me out. We have a customer with a C1 vette and a 350ci motor. The bolt pattern on the block(for the bell) has 7 bolt holes like an LS block but it is my understanding that if there is a provision for the Z-bar pivot ball in the block, then it is not an LS.
Can anyone confirm or refute this???
We sent him an LS style flywheel and the bolt holes are off by about 1/2 of a bolt hole and I am stumped.
Thanks in advance for any help on this.
Richard
Tech Support
Keisler Engineering
Old Jan 5, 2007 | 10:39 AM
rj8806's Avatar
rj8806
Anybody
Richard
Old Jan 5, 2007 | 11:15 AM
shafrs3's Avatar
shafrs3
Not sure Rich, what do you mean by LS?
Old Jan 5, 2007 | 11:36 AM
rj8806's Avatar
rj8806
Please forgive my ignorance but is there a difference between LS blocks?? My understanding is that ALL LS blocks have 7 bolt holes for the bellhousing mounting and there IS NOT a provision for the z-bar pivot stud. Is this correct? My guy has the 7 bolt holes AND the provision for the ball stub which contradicts my understanding of the LS block.
Richard
Old Jan 5, 2007 | 11:49 AM
big_G's Avatar
big_G
PM sent
Old Jan 5, 2007 | 12:04 PM
rj8806's Avatar
rj8806
Originally Posted by big_G
PM sent
That cleared up everything, Thank you Very much.
Richard
Old Jan 5, 2007 | 12:12 PM
gkull's Avatar
gkull
PM sent
could you send me the PM for the answer also?
Richard this is what I was thinking:
In 1986 a crankshaft and flywheel change was made. 1986 and newer Chevy engines will not accept older flywheels due to the different crank flange and bolt pattern. Older bellhousings, however, will work on 1986 and newer engines.
Old Jan 5, 2007 | 12:17 PM
big_G's Avatar
big_G
Yes, you got it. One piece rear main blocks use the smaller flywheel bolt pattern, like the ZZ-4.
To I Need Your Help
