temp sensor for edelbrock heads
has anyone tryed to use the stock style temp sensor for edelbrock rpm heads? the stock thread in 1/2 and edelbrock uses a 3/8. i tried looking for a npt style reducer but was unsuccessful. i can go from 3/8 tp 1/2 but not 1/2 to 3/8. surely someon has tried this? (o ya i have a '79 vette)
St. Jude Donor '03-'05-'06-'07-'09
I have the same issue with the aftermarket alum heads....this ones not in the instructions!
I am in the process of an engine build. I bought a water temp sensor for a 79 Vette. It is a 3/8" NPT. Hopefully it will be close to the calibration of my 72....well see...
I paid $11 at Advance. Be sure if you buy one, that it states its for a gauge and not a dash light. Some aftermarket intakes have 1/2" openings, one for the heater and one on the other side....best of luck
Ran into the same situation on a 68 Camaro I used to have.
Go to your local parts place with the old sensor, give a brief explanation of what you are doing, tell them you want this type sensor with a 3/8 thread. An experienced parts person will know what to do.
I don't remember what vehicle the sensor was for that I ended up with(I think it was out of a '90s pickup), but it worked fine
I just ran into the same problem. The guy at Autzone went through almost every Chevy sensor in the store. I think it was the 1983 6 cylinder Chevy Celebrity sensor that was 3/8 with the single connection, which worked with my new vortec heads and the original temp gauge in my '77. Good luck.
This is what I did with my aluminum head. Just took it into the machine shop and had them drill and tap the hole to a larger size. I think it cost about $25.
Ran into the same issue with my Darts on my 79. I just took sender in hand down to the hardware store and got a brass fitting. Male side threads into the head and female side accepts the sender. Maybe cost a couple of bucks.
chris70lt1 - i just called corvette paramedics, there sending me a sensor that they had supplied others with same issues, did you check your resistance of it before you installed the sensor or does it read close enough?
