What Is This?
Old Sep 30, 2001 | 05:50 PM
Tom Johnson's Avatar
Tom Johnson
Default What Is This?
1971 Vette, 350/270, Auto, Air It looks like a relay of some kind. It is the size of a small wooded match box and is bolted to another, what looks like a relay, on the drivers side fire wall in the engine conpartment. It has two terminals. One terminal has a light green wire and the other terminal has a black wire and a light brown wire. What is it?
Old Sep 30, 2001 | 06:41 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: What Is This? (Tom Johnson)
i think its the horn relay, not sure tho.
Old Sep 30, 2001 | 06:57 PM
GaryS's Avatar
GaryS
It is not the horn relay since that is located at or near the left fender about 12" from the firewall. Some of the boxes on the firewall are the terminals for power windows and I "think" the timer for the CEC (emissions doodad unique to 71. I don't have a wiring diagram for a 71 but anyone with one should be able to help you positively indentify this.
Gary
Old Sep 30, 2001 | 07:12 PM
Corz's Avatar
Corz
Default Re: What Is This? (GaryS)
i dont have power windows, and the box is in the same spot as his. I got a wiring diagram for a 69, might be the same, gotta go hunting now.
Old Sep 30, 2001 | 07:31 PM
Tom Johnson
Default Re: What Is This? (Corzvette69)
I have three repair manuals. None of there wiring diagrams were any help.
Old Oct 1, 2001 | 08:20 PM
Tom Johnson
ttt
Old Oct 1, 2001 | 09:32 PM
rickales's Avatar
rickales
On our 68 L36, its a 30A circuit breaker that supplies unfused B+ for the taillights, side markers and maybe the wiper motor. It doesn't show up on the AIM schematic, but the nuts mounted in the firewall looked factory.
Old Oct 2, 2001 | 05:02 PM
Tom Johnson
I disconnected the wires and I still have tail lights, side markers and wiper motor. I suppose while its disconnected I could check all other systems.
Old Oct 2, 2001 | 09:03 PM
rickales's Avatar
rickales
Disconnect and see if it'll will turn over?
Old Oct 2, 2001 | 09:59 PM
Tom Johnson
Disonnected it and she fired right up.
To What Is This?
