Bosch Platinum gapping
Old Jan 5, 2007 | 06:10 PM
sjmaster's Avatar
sjmaster
Default Bosch Platinum gapping
What should the gap on Bosch Platinum 4008 bet set to? Application 77 small block, light mods. Is this the same as a stock plug gap??
Thanks in advance
Old Jan 5, 2007 | 09:51 PM
andylmusic76's Avatar
andylmusic76
that's funny...i just installed those on my 77 three days ago. sorry i can't help ya
Old Jan 5, 2007 | 09:56 PM
jerrylee's Avatar
jerrylee
The gap should be .035"................Jerrylee///
Old Jan 5, 2007 | 11:54 PM
Big2Bird's Avatar
Big2Bird
Thanks in advance
Set it to stock. Plug gap is determined by coil output, not plug type.
Old Jan 6, 2007 | 01:30 AM
sjmaster's Avatar
sjmaster
Excellent, thanks.
I would offer this info: a NGK engineer advised that the fine tip plugs require less voltage to fire. Sparks can more easily jump from points than blunt tips.....and it is often beneficial to run a larger gap with fine tip. But then some fine tip / precious metal plugs have specific warnings not to regap...probably since damage could easily occur.
Old Jan 6, 2007 | 09:47 AM
Big2Bird's Avatar
Big2Bird
Excellent, thanks.
Then I will offer this. It's about having the potential to jump the gap, not about the shape of the tip. It might matter on a lightning rod, but at 35,000v I doubt much difference.
As for gap, If you increase it, they say it helps low end torque. At high RPM you want it smaller to prevent mis fire.
To Bosch Platinum gapping
