Bubba cut my temp sensor wire!! Need help.......
Old Jan 5, 2007 | 10:41 PM
sperkins's Avatar
sperkins
Default Bubba cut my temp sensor wire!! Need help.......
Then he added an aftermarket guage and screwed it into the dash.
Anyway, I now have the center cluster out and wanted to check to see if the factory guage still works. Problem is there isn't a sensor at the end of the wire now. Is there a way I can ground out the back of the guage to see if the needle will move?
:scratch-head:
:killbubba:
Old Jan 5, 2007 | 11:23 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
BUBBAS BEEN BUSY,,,,
Old Jan 5, 2007 | 11:42 PM
sperkins's Avatar
sperkins
If you only knew....
Old Jan 6, 2007 | 09:25 AM
jnb5101's Avatar
jnb5101
you can ground the gauge, but be sure to ground the correct side-one side goes to 12 volts, the other to the sender(which i guess should be called a receiver because it's grounded). if you're not sure which side to ground, run a temporary wire from each side of the gauge(one at a time)to the sender. this will test the sender and gauge. you can't simply use a volt meter on the gauge terminals, because in an open circuit(sender not connected) both sides of the gauge will read 12 volts.
Old Jan 7, 2007 | 02:19 PM
sperkins's Avatar
sperkins
I located the temp sensor wire coming out of the harness near the alternator pig-tail. How can I test to see if the guage still works?
Old Jan 7, 2007 | 02:43 PM
Big2Bird's Avatar
Big2Bird
Tie it to ground. Turn on the key. Should go to hot peg.
Old Jan 7, 2007 | 02:47 PM
Duke94's Avatar
Duke94
Maybe one of these will help.
http://lbfun.com/Corvette/Tech/vette...g%20gauges.pdf
http://lbfun.com/Corvette/Tech/vette...p%20sender.pdf
Old Jan 7, 2007 | 07:43 PM
sperkins's Avatar
sperkins
Thanks. I'll try that.
That's a load of really good info. Thanks a ton!
Old Jan 7, 2007 | 08:29 PM
Big2Bird's Avatar
Big2Bird
Goos stuff, a keeper.
To Bubba cut my temp sensor wire!! Need help.......
