I don't think there's such a thing as a bolt in bung.
You could possibly make your own, but the length required may shroud the tip of the sensor or the hole in the header will be huge if you tap the outside of the bung. Spark plug anti-foulers can be cut down to make these on a budget, but you'd have to weld them in.
I have the ceramic coat Hookers as well. They sell the one that are clamp on, you just have to drill the hole out up underneath on the inside the collector and its like a big hose clamp that goes around it and hold the sensor in place.
