Help! Can not get oil Primed ?????
Old Jan 6, 2007 | 07:29 PM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Default Help! Can not get oil Primed ?????
Hey guys, got the engine put back together, loaded it with oil. It is on the engine stand, started to prime yet oil only comes out on Drivers side. Oil will not come to passanger side???
The sope of thing: The engine is tilted a little bit forward on engine stand. New pump, new lifters, new spings, new oil pan.
Thanks for any help. Tired and frustrated.......
This is on the '82
Old Jan 6, 2007 | 07:33 PM
sly vette's Avatar
sly vette
Have you tried tilting the engine back some...I dunno!
Old Jan 6, 2007 | 07:36 PM
LFZ's Avatar
LFZ
turn your crank...get some revolutions going..this will get oil to come out the other side.
Old Jan 6, 2007 | 07:38 PM
Perfomer's Avatar
Perfomer
You will not get oil through all push rods with the motor not running. If you rotate the motor it will go through the other push rods . Anyway you are getting flow to the front cam bearing and that is all you need to lub until you start the motor
Old Jan 6, 2007 | 07:43 PM
Binnie77's Avatar
Binnie77
What are you priming it with? You have to use the correct priming tool on the newer blocks in order to get oil to both sides. You need a primer with the bushing to pressurize the valve train. The older primers will only oil one side of the newer engines.
Old Jan 6, 2007 | 08:27 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
If you are using a oil pump primer that is just the rod and not like the body of a distributor, It will not oil both sides. I use an old distributor body, grind off the gears and cut down the body. The way the oil passeges are, the oil is pushed from one side of the block to the other in the distributor boss of the block. PM me for more info.
Old Jan 6, 2007 | 08:32 PM
norvalwilhelm's Avatar
norvalwilhelm
Priming takes time. I too use an old modified distributor but it tends to overheat the drill so I do it in stages. I pime for a while, turn the crank a little etc etc.. Eventually all ALL pushrods start dripping oil. Some are very slow but by being patient, turning the engine and running the drill all the valve train will start dripping oil.
Old Jan 7, 2007 | 08:41 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
This has got to be what it is. We are using the rod type primer on the original '82 block. We have turned the crank while running primer.
tt
BTW, this is my first try at doing such engine work, just wanting to be sure I do not do anything stupid, so I am checking everything twice!
To Help! Can not get oil Primed ?????
