Clutch Pedal Noise
Old Jan 6, 2007 | 09:41 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Clutch Pedal Noise
Any ideas on a strange noise coming from my 1980's clutch pedal? Makes a rattling nose unless I ride with my foot on the pedal with very light pressure. Almost as though there is a rubber stop missing or a bushing missing.
Old Jan 6, 2007 | 09:50 PM
SIXFOOTER's Avatar
SIXFOOTER
Return Spring gone or loose, Throwout bearing about to bite it
Old Jan 6, 2007 | 10:27 PM
Big2Bird's Avatar
Big2Bird
Throwout bearing
Old Jan 7, 2007 | 07:52 AM
kb2fzq's Avatar
kb2fzq
Originally Posted by Big2Bird
Throwout bearing
yup
Old Jan 7, 2007 | 10:52 AM
MidShark's Avatar
MidShark
Probably is noise from the throwout bearing, but could just be from improper linkage adjustment (bearing riding on the fingers of the pressure plate). Check for worn linkage, too.
Rich
Old Jan 7, 2007 | 10:56 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
While it sounds like the throwout bearing, you want to be sure to identify the actual problem before pulling the tranny and replacing it only to find out it's not the culprit.
Old Jan 7, 2007 | 11:09 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Excellent suggestion. There is the return spring on the Z-bar (don't know how many of those I have seen broken) and anti rattle springs on the fork push rod. Make sure all of that is good before pulling the trans.
Old Jan 7, 2007 | 09:26 PM
80TexasC3's Avatar
80TexasC3
Is definitely coming from under the dash in the pedal area...
Old Jan 7, 2007 | 11:25 PM
redvetracr's Avatar
redvetracr
you may have a bad bushing, or a few bad bushings....a real pain in the A$$ to fix.
...redvetracr
To Clutch Pedal Noise
