75 Corvette is running hot
Old Jan 7, 2007 | 08:16 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would replace the shroud with the proper seals and the thermostat and then see where you are. These are 2 major things that can cause overheating. If the individual who worked on your car suggested running without a thermostat, I would seek advice from someone else in the future.
Old Jan 7, 2007 | 09:01 AM
Fl_Mike's Avatar
Fl_Mike
Whats the hottest temp car should reach at idle, after 10 or 15 minutes
should it climb to 135* or maintain a lower temp when all is working right?
Old Jan 7, 2007 | 09:03 AM
Fl_Mike's Avatar
Fl_Mike
I meant to say 235*
Old Jan 7, 2007 | 09:10 AM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by Fl_Mike
I meant to say 235*
If all is operating properly with all necessary parts, the temp should rise to the thermostat rating and remain there.
Old Jan 7, 2007 | 12:03 PM
Big2Bird's Avatar
Big2Bird
