Potential Issue?
Old Jan 7, 2007 | 02:53 PM
cajos's Avatar
cajos
Default Potential Issue?
During some repairs on my vette I came across this.
It seem that one of mounting flanges has broken off of the belhouse.
You can see the in side of the belhouse.
How serious is this?
Old Jan 7, 2007 | 02:59 PM
Big2Bird's Avatar
Big2Bird
It looks like it just holds on the dust cover, correct?
Old Jan 7, 2007 | 03:03 PM
cajos's Avatar
cajos
Yes, that is what I was thinking only a dust cover. BUT inside is flywheel and stuff?
Old Jan 7, 2007 | 03:06 PM
Big2Bird's Avatar
Big2Bird
Cosidering where you are, and how minor this is, I would not lose sleep over it. It will rattle, and you could leave it off without too much harm.
Old Jan 7, 2007 | 03:12 PM
cajos's Avatar
cajos
JUst double checking, thanks. Should I tape it off or so?
Old Jan 7, 2007 | 03:14 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Doesn't look like a problem. Maybe drill a small hole and zip-tie it(bubba?). I have 2 bottom bolts on my manual trans inspection cover that I can't get to because of the big oil pan, I just used wire ties!
Mike
Old Jan 7, 2007 | 03:40 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Build it up with a little JB weld, drill, tap it and call it a day!
Old Jan 7, 2007 | 10:19 PM
TimAT's Avatar
TimAT
That's one of a cast of thousands. Those #10 screws have popped the corners off of more bellhousings---
Really not an issue,other than the tin may rattle. If you can see a spot,drill another hole thru the tin and into the trans, put another screw in it and drive on.
Yes, the flexplate/flywheel and convertor is in there. I know guys that have ran many years without any cover at all.
To Potential Issue?
