Negative Ground Cable attachment problem
Old Jan 7, 2007 | 09:37 PM
davidbr93's Avatar
davidbr93
Default Negative Ground Cable attachment problem
Today I went to loosen the neg ground cable at the frame and found it to spin freely but not detach. After spending some time trying to extract the bolt I decided to cut it. My question is how to replace the bolt and nut it attaches to. There is little access to that part of the frame and I'm wondering how get a nut positioned over the hole. Has anyone run into this problem before?
Old Jan 7, 2007 | 09:45 PM
tellcom2001's Avatar
tellcom2001
on my 79 vette my ground is above the starter. but i added a second ground to the block next to the oil pressure sending unit and bolted it to the frame. i say find a new spot on the frame to bolt it to and add some extras
Old Jan 7, 2007 | 09:59 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Which ground cable are you talking about? There are many.
If you are referring to the ground cable directly from the battery, I don't believe that has a nut behind it - just threaded into the cross member. Should have a star washer between the cable & the cross member too.
Old Jan 7, 2007 | 10:26 PM
big_G's Avatar
big_G
Try to get a nut back there, don't forget the star lock-washer.
Old Jan 7, 2007 | 10:35 PM
68/70Vette's Avatar
68/70Vette
On my 68, with a ZZ4 and ministarter, I decided not to use a ground strap from the starter to the motor mount, which is the stock routing. Instead, I drilled a hole in the frame near the ministarter, tapped the hole, and now I used that the as the main engine to frame ground routing. I think you can do something like this also if you want.
Old Jan 8, 2007 | 07:58 AM
77BuffaloVet's Avatar
77BuffaloVet
If this is the one you are talking about, there is not a nut. The bolt threads into the cross member. If it spins freely you will have to find another place to bolt it to the frame or try a bigger bolt. I went up one size in bolts and drilled out the connector to fit. As long as the metal is clean the bolt is tight it will work fine.
Old Jan 8, 2007 | 09:30 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
mine was a nut and bolt and i was able to get at both. you could always drill a new hole and reposition it.
Old Jan 8, 2007 | 10:48 AM
wrc69v's Avatar
wrc69v
both attachment points for a ground cable (engine to frame, battery to frame) can be re-threaded with a tap and die set, then use a bolt that fits that tap and your done. I did this 5 years ago and still have the same battery and no electrical grounding problems.
good luck!
To Negative Ground Cable attachment problem
