Rubberized Edge Protector Flat Sheet Metal Press On Protector
Old Jan 8, 2007 | 04:40 PM
Hadez's Avatar
Hadez
Default Rubberized Edge Protector Flat Sheet Metal Press On Protector
I am looking for the following….weather strip/rubber edge seal protector that is kind of like a "U" shapped where you can press it on to a straight flat or slightly curved edge. This would be a long strip that is about 1/2" tall and just wide enough to where it would wrap around the edge that I am trying to cover up/protect.
Imagine if you cut a piece of flat sheet metal about 1/8" thick and you wanted to cover-up/protect the edge with a hard rubberized long somewhat flexible being able to follow a soft curve in a U-shape that you press the "U" shapped piece onto the edge and should stay there 99% of the time that would cover up about 1/2" of the edge. I have seen this stuff several times before on cars/boats/etc but when I go to search for it I can't find the exact stuff I need as there are a ton of choices out there and it is too hard to tell from a pic if it is the stuff I am looking for. I tried Home Depot and the guy knew exactly what I was looking for but they don't carry it. It is not really a weather strip, but more of a edge finish/protector rubberized stuff that I am looking for.
Old Jan 8, 2007 | 05:24 PM
SJW's Avatar
SJW
Try McMaster-Carr:
http://www.mcmaster.com/
Search for "edge" on their site. Then check out "Edge Trim", in particular, from the search results. I see some stuff there that sounds like what you're describing.
Don't know if they'll have exactly what you're looking for, but there's a good chance they will.
Be well,
SJW
Old Jan 8, 2007 | 05:30 PM
Hadez's Avatar
Hadez
Ahh....Many Thanks!!! Exactly what I was looking for.
Old Jan 8, 2007 | 05:40 PM
SJW's Avatar
SJW
Happy to help. Glad you found what you were seeking. There isn't much that McMaster-Carr does not have...
Be well,
SJW
Old Jan 8, 2007 | 06:56 PM
Twin_Turbo's Avatar
Twin_Turbo
Yes there is.....international shipping they do however accept international credit cards
To Rubberized Edge Protector Flat Sheet Metal Press On Protector
