540 Dyno Run II
Old Jan 10, 2007 | 06:14 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default 540 Dyno Run II
I just got off the phone with TNBUSA. They finally got his motor on the dyno today and called him with the results. I had told him earlier to call me when he found out what the motor made.
Mike can add all the details but the hard numbers are
719 HP and 687 Ft Lbs on 93 pump gas. The pull was stopped at 6000 RPM and HP was still climbing.
Sounds like Mike put together a pretty darn good combination of parts!!!
I put this in the general section too. I know some may not get the look at it over there.
Old Jan 10, 2007 | 06:26 PM
langg's Avatar
langg
What are the head and cam specs?
Old Jan 10, 2007 | 07:01 PM
TNBUSA's Avatar
TNBUSA
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07
Langg, its got AFR 315's with 114cc chamber. The cam is a Crane Powermax hyd roller .632 .632 .256 .264 @.050 on a 114 lobe center.
Old Jan 10, 2007 | 07:12 PM
pef427's Avatar
pef427
Congrats Mike. I can't wait to see you guys at CF CI VIII. There's gonna be a parking lot full of BB Beasts! Which intake/carb setup did you go with? Let's see some pics ASAP.
-Patrick
Old Jan 10, 2007 | 07:38 PM
TNBUSA's Avatar
TNBUSA
Cruise-In VIII
Hey Patrick! I went with the super victor and a pro-systems 1120. Probably a little big for my combo but I will be set if I decide to put in a real cam. I cant wait for the cruise in but I still have a ton to do, I hope to get done by then.
Old Jan 10, 2007 | 07:48 PM
langg's Avatar
langg
Sounds really great! no dyno run and winter got here before I got a chance to drive mine (also 540). Chevy 188 heads, Edelbrock 7162 cam and the Edelbrock 2 fours set-up.
Old Jan 10, 2007 | 09:26 PM
ML67's Avatar
ML67
Congratulations! That will make for a spirited ride.
Mark
Old Jan 10, 2007 | 10:09 PM
pef427's Avatar
pef427
Lang,
Post some pics of your motor. 2x4's are cool!
-P
Old Jan 10, 2007 | 10:42 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Sweeettttttt........... great to hear it!!
That's going to be a heck of a lot of fun!! Glad to know I'll have someone else at the Cruise IN with a *small block* 540" motor. All the rest of these guys are at 548", 555", 598" and 638"s!! We're the underdogs!!
I bet that sucker is smooth down low. The TQ right off idle is going to be incredible...but did I hear "put in a real cam"?????
He, he, he.....I used to ask Mark if it was possible to become *jaded* with 800 hp on the street......look at you...just busted 700HP on an easy pull and already eyeballing the next level!! Good news is that with the rest of your combo you truly are just a cam change away from a completely different animal.
I want to see those 2x4's and lets make some dyno runs Langg!!
JIM
Old Jan 11, 2007 | 06:39 AM
ML67's Avatar
ML67
JIM
Sadly, it is not only possible, but inevitable......
Old Jan 11, 2007 | 07:58 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Man is that going to be a fun ride!
To 540 Dyno Run II
