82 rear spindle removal
Old Jan 10, 2007 | 08:25 PM
roy Arrington's Avatar
roy Arrington
Default 82 rear spindle removal
Need some advise. I have the car jacked and ready to remove the spindle for bearing replacement. All has gone according to plan until tonight. I have a spindle knocker and have been hammering on it for about 30 minutes with no apparent movement. I have the setup tools but did not purchase the spindle removal tool due to cost.
Anyone got any hints on how to proceed? keep on hammering or remove the trailing arm and seek out a machine shop?
Old Jan 10, 2007 | 09:21 PM
1981 corvette's Avatar
1981 corvette
Roy,
I used the spindle knocker before with success. Removed the trailing arm from the car, held in one hand, and a large hammer in the other, and drove the spindle out. You can even try a sledge, worked for me. Hope this helps.
Old Jan 10, 2007 | 10:33 PM
Vette Gator's Avatar
Vette Gator
It's probably easier to use a hammer and knocker with the TA out of the car. I had to beat pretty hard with a hammer to get mine out and it was a lot easier to be able to hammer straight up and down instead of doing on the side. I'd also rather set up the end-play on the bench rather than trying to do it while the TA is still attached to the frame. Not that it can't be done the other way, but it's just easier.
Old Jan 11, 2007 | 06:22 AM
roy Arrington
Thanks for the feedback. I was rapidly coming to that conclusion BUT didn't want to disassemble more if it was not necessary. It was not easy trying to get a good hit on the knocker while laying under the car.
I'll update soon
Old Jan 11, 2007 | 10:43 AM
GTR1999's Avatar
GTR1999
I would never setup bearing in the car. I know it has been done but it not what I recommend. Remove the arm, replace the front bushings, paint it and then setup the bearings. One thing I do is parallel grind the shims,spacers, flange mating surfaces- all mating parts will have a flat finish to them- makes a big difference in the end result of the job. C clamp the mag base too-there can be no play at all in the indicator.
Old Jan 11, 2007 | 01:41 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Take them to a shop that knows what they're doing. Use the knocker if you want to buy new bearing supports.
Old Jan 11, 2007 | 08:20 PM
roy Arrington
I'm beginning to think that is the safest way to go. I bought the assembly and setup tools thinking that I could change the bearings myself. I think I'll pull the arms and have the old bearings done at a shop that has the tools and experience to pull this off.
I hate to do that because I have invested in the tools and parts...
thanks for the feedback and advice.
Roy
Old Jan 11, 2007 | 08:42 PM
KJL's Avatar
KJL
A small amount of end play is required as you do not want to preload the bearings. I forget what the spec is. Be sure to also check the spindle run-out and the rotor run out as well. Installing the new bearing races will be easier if the the a arm is off as well. I am sure any service station would push out the spindles for you for a few bucks. If you live in Atlanta, I will do it for you!!
Old Jan 11, 2007 | 10:35 PM
SmokinBBC's Avatar
SmokinBBC
Can you rent the tool from Autozone?
Old Jan 13, 2007 | 07:11 PM
roy Arrington
Default spindles are out - now how about the races???
The spindle knocker worked with patience and effort. Now I'll take the spindles to a shop to get the outer bearing pressed off.
Question of the day. How difficult is it to knock the races out. I'm ready to start. Does heating the housing make the effort any easier?\
Old Jan 14, 2007 | 03:36 PM
GTR1999's Avatar
GTR1999
Roy,
A brass drift will drive out the races. The outer bearing is a trick to get off without the right puller. Be sure your spindles are not damaged when you get them back.
Old Jan 14, 2007 | 07:28 PM
KJL's Avatar
KJL
Because you are not going to reuse the races, a steel drift punch will work fine. The carrier has notches in it to allow you to access the rear of the races. Take your time and tap them out as evenly as possible. If you save to old races you can sand/grind the outer diameter...why? when you install the new races, you can use these when tapping them in. Place these over the new ones and drive them in by tapping the old ones. Flip them over so you are tapping the broad face. When seated, because you ground them, they should drop right out. Works like a charm. Make sure you keep track of which bearing goes with which race. Mark them.
To 82 rear spindle removal
