Edelborck Carb Help Needed
Old Jan 11, 2007 | 08:56 AM
hayman's Avatar
hayman
Default Edelborck Carb Help Needed
I have installed a 1406 Edelbrock carb on my 350 and have it running pretty well now. I installed a O2 sensor and a Fuel/O2 ratio gage and have the idle, cruse and WOT all set.
The only problem I have is the hesitation at quick throttle. It seems to be a lean mixture issue. I have a Accelerator nozzle kit on order and should get it today.
Can anyone advise me as to which nozzle to use? Just trying to save some time and figure someone else has all ready gone thru this.
TIA
Bill
Old Jan 11, 2007 | 09:34 AM
68RATVT's Avatar
68RATVT
I had the Edelbrock 1813,800cfm, same hesitation,changed the pump,added dual fuel feed, adjusted, still couldn't fix it. So I put on a Holley and no more problem....Maybe I don't understand the Edelbrock,I don't know...
Old Jan 11, 2007 | 10:02 AM
04 RAG TP's Avatar
04 RAG TP
Default carb hesitation
Edelbrock sells a calibration kit for your 1406 carb through summit, part number EDL-1487 for 35.00. You might want to ask them if they sell an accelerator pump cam kit. Most of the time your accelerator pump isnt squirting fuel long enough and your engine will lean out and you feel a bog/hesitation, sucks. Ensure you check that your vacumn advance is working before spending any more money on carb parts. Holley carbs do offer more tunability and faster parts swapping ability for the weekend garage parties... Good luck, Aaron
Old Jan 11, 2007 | 10:27 AM
hayman's Avatar
hayman
I already purchased the calibration kit. I used the fuel/O2 gage to set the idle mixture. Changed the primary rods to get the correct ratio for cruse and no change was needed for WOT.
Only issue is the stumbling on acceleration. I have the linkage set to the hole closest to the fulcrum.
Bill
Old Jan 11, 2007 | 10:33 AM
1970-Bronze's Avatar
1970-Bronze
Is the stumble only from inital acceleration?
I think you actually need to move the accelerator pump in the opposite direction.
It could also be your "Step-up" springs.
What values are you using to set your A/F for Idle, Crusing, and WOT?
Let me know.
Old Jan 11, 2007 | 01:20 PM
hayman's Avatar
hayman
Let me know.
I changed the step up spring to the blue color and it did not change the stumble. I know now that that will need changed to a heavier spring. The Blue was the middle of the pack.
If I move the linkage away from the fulcrum then the travel will be less but will have more force. Think of it as a seesaw
The values I am adjusting to is 13 to 14 : 1.
Bill
Old Jan 11, 2007 | 01:49 PM
1970-Bronze
Bill,
What kind of O2 sensor are you using? If it's a Heated Wide-band you should be able to tell if your rich or lean on inital acceleration.
If I remember correctly, you want the shorter travel because that has a larger "squirt". If your lean, then you need the larger "squirt" but if your rich, it needs to move the other direction which would be a "bog".
How much vacuum do you have at idle?
I noticed on my EPS 800 that I had to stay closer to 13 than 14 A/F at idle.
So, I would shoot for an idle around 13, about 14 for the cruise circuit and you need to be down around 12.5 for WOT. I'm still working on my cruise circuit. I had to order some new rods to get the correct combination but I haven't had a chance to test.
I would also suggest for now to go with the lightest springs (Blue) until you resolve the stumble. Then start adjusting upwards until you have a stumble and then go back one spring.
What's the current configuration - Jets and Rods?
Tim
Old Jan 11, 2007 | 02:29 PM
hayman's Avatar
hayman
Bill,
Tim
Thanks Tim,
I am using Edelbrock's Sensor and gage kit, don't know the part number off hand.
I have about 14 to 16 hg at manifold at idle.
I changed the stock primary rod to the riches rod in the kit because at cruse it was so lean it did not light the 15:1 light (this is a led gage read from right 15 to left 11) unless I just barley let off the accelerator. As soon as I applied any pressure to the peddle all lights would go off. I am getting a good 12 at WOT
And 14 at idle.
I was thinking does the accelerator plunger regulated but spring pressure? If this is the case then it makes sense to put the larger diameter nozzle from the kit.
Can you explain how the spings function?
Bill
Old Jan 11, 2007 | 04:05 PM
1970-Bronze
Bill,
I'm not sure I understand your question.
The "Step-up" springs (3" Hg (blue), 4" Hg (yellow), 5" Hg (orange), 7" Hg (pink) and 8" Hg (plain) springs) are used to tune the rate of enrichment. Basically how fast the metering rods react to changes.
The Accelerator Plunger spring to the best of my knowledge is not a factor. It has more to do with the volume of the plunger and size of the nozzle.
If you have 14-16", you should be able to move more towards the orange or pink spring in your final configuration.
Tim
Old Jan 11, 2007 | 05:14 PM
hayman's Avatar
hayman
Bill,
Tim
Thanks for the help, I got the nozzles and will try to get out tonight and change them over.
Bill
Old Jan 11, 2007 | 08:33 PM
bozzman3's Avatar
bozzman3
TIA
Bill
Where did you get a accelerator nozzle kit from?
Old Jan 12, 2007 | 08:56 AM
1970-Bronze
The Accelerator kit is listed on Edelbrock's web page and Summit carries it.
Old Jan 12, 2007 | 06:33 PM
RadicalPursuit's Avatar
RadicalPursuit
Default Carb Tuning
Your topic couldn't have come at a better time. I have a newly installed Edelbrock 1406, that I am trying to fix the "stumble or hesitation." Don't forget the Edelbrock web site for tuning tips as well. Sounds like the same issues. thanks for posting the topic.
Old Jan 12, 2007 | 07:30 PM
75coupered's Avatar
75coupered
If you haven't already download the Edelbrock Carb Owners Manual from their web site and it will take you through all of the spring set-up by color etc. Very useful
Also on the accelerator pump are you should have 3 holes for mounting the linkage. The one closest to the carb and also the highest hole is for richer than baseline (the center hole) and leaner the last, bottom hole furthest away from the carb body.
In you case it seems that you want to set it to the first hole, richer, and see if that takes care of the stumble.
Good luck
Old Jan 12, 2007 | 08:04 PM
bozzman3's Avatar
bozzman3
Oles carberutor out of CA.sells a accelerator pump with a more active spring that is supposed to help with a hesiation.A guy named Henry is on this forum.I think that different sized accelerator nozzles would correct your hesiation.
To Edelborck Carb Help Needed
