Standard deck height is 9.025" - you''l have slightly higher compression, might want to look into different head gasket manufacturers, Small block head gasket thickness can be between .030" and .050", I think FelPro is .041".
Do you need to lower the compression to use pump gas ? What engine is this ? What pistons, heads and compression ??
