Jacking the car up
Old Jan 11, 2007 | 11:36 AM
Doug Maitlen's Avatar
Doug Maitlen
Default Jacking the car up
I drive a 1979. What is the safest way to place the rear end of the car on jackstands. Where do I place the jackstands?
Old Jan 11, 2007 | 11:45 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I usually place my jackstands at the rear of frame rail just in front of the rear tires. I jack the car up just in front of this area.
Old Jan 11, 2007 | 12:22 PM
Wuttin's Avatar
Wuttin
Park on a nice level surface and chock the front wheels. Unlatch your Ttops but leave in place. Put a good 3 ton hydraulic jack under the differential, in front of the ears on the differential cover that hold the spring. Car will lift nicely from the center so you can position both stands as above.
Old Jan 11, 2007 | 12:41 PM
S489's Avatar
S489
assuming your working on concrete and not asphalt or dirt
Old Jan 11, 2007 | 12:57 PM
VCuomo's Avatar
VCuomo
Check out this thread: http://forums.corvetteforum.com/show...ght=jacking+up
To Jacking the car up
