Need a Measurement
Old Jan 11, 2007 | 06:02 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Need a Measurement
For those with factory aluminum wheels i need the mesurement of the centerbore where the hub comes through. Thanks in advance.
Old Jan 11, 2007 | 06:16 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
On my 82 its 3-1/4 inch
Old Jan 11, 2007 | 06:46 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
why don't you just measure the outer diameter of your axle's hub - that's lot easier to measure than the hole.... give it a few thousands clearance
Old Jan 11, 2007 | 06:59 PM
Silver00V6Camaro
I have done that. The problem is i dont want to order the wrong Hub centric rings that was posted in my other thread. I have tried to find some locally and have had no luck. The reson I asked this question is because my rims measure the same as the measurements posted. Where the hub sized different in 75? Also while i was out looking for the centric rings today a wheel shop told me that it might not be the problem why my wheels feel off and broke the studs he said that i might have the wrong lug nuts. Well i bought tapered lug nuts because it looks like my wheels have tapered seats in them. Here is a pic of my wheels and the new studs in the hub. Also whats is the recommended torque when torquing the studs and wheels. Sorry for all of these questions, but this is new to me and the first time something like this has happened to one of my vehicles. So thanks in advance and for everyone who has helped.
Here is the link to my other thread.
http://forums.corvetteforum.com/show....php?t=1590666
Pics
Old Jan 11, 2007 | 07:02 PM
Silver00V6Camaro
If i am correct on measureing my hub i came up with 2.75 inches which is aroung 70.3mm what most of the sites I have found say fit a vette and other gm cars. The main problem is finding the hub centric ring that fits my rim unless im not understanding how they work.
Old Jan 11, 2007 | 08:13 PM
Older Than Dirt's Avatar
Older Than Dirt
Do you know anyone who has a set of micrometers? You could take your wheel to a machine shop and let them measure the wheel bore with an inside micrometer. I know a guy that would do it for you.
Old Jan 12, 2007 | 04:59 PM
Silver00V6Camaro
ttt
To Need a Measurement
