Hooker side pipes and O2 sensor
Old Jan 13, 2007 | 02:35 PM
jerome1979's Avatar
jerome1979
Default Hooker side pipes and O2 sensor
Where can i insert a O2 sensor?
Ceramic coated and welding is it compatible?
Old Jan 13, 2007 | 02:54 PM
mooneyd's Avatar
mooneyd
You will need to grind off the ceramic coating in the area where you want the O2 bung.
Old Jan 13, 2007 | 03:01 PM
RadicalPursuit's Avatar
RadicalPursuit
Default Oxygen Bung
www.summitracing.com search on oxygen bung
HED-21107 or HED-21106 Oxygen Bung Reducers $18.00
HED-15205 Weld in bung $10.00
Old Jan 13, 2007 | 06:31 PM
Z-man's Avatar
Z-man
You're facing the same problem I had. That's one of the reason I made custom headers and used only the Hooker sidepipes. I put a bung on each side so that I could switch the O2 sensor to check the other side if I wanted to...
To Hooker side pipes and O2 sensor
