Rear Sring - 7 or 9 leaf?
Old Jan 13, 2007 | 06:15 PM
davidbr93's Avatar
davidbr93
Default Rear Sring - 7 or 9 leaf?
I'm in the process of dropping the differential to replace the rear cover which had cracked. Today I removed the rear spring (not fun) which is quite rusted. It got me to thinking about replacing the spring. Looking online I notice there is a 9 leaf standard or 7 leaf HD replacement for my car. What is the difference between the two? Any recommendation as to which to replace mine with? Thanks! Dave
Old Jan 13, 2007 | 06:47 PM
jerrylee's Avatar
jerrylee
Default Springs...
I believe the 7-[heavy duty]- is 4 the big blocks..n the 9 is standard....Have u looked into composites....That's the way I'm going when I do my rear this month..............Jerrylee///
Old Jan 13, 2007 | 06:54 PM
Tankers's Avatar
Tankers
The 7 leaf spring gives a pretty stiff ride.
Old Jan 13, 2007 | 07:00 PM
MN80Vette's Avatar
MN80Vette
The 7-leaf spring was also part of the Gymkhana suspension package. My '80 came with that option. I since replaced with an equivalent composite spring. They weight abou 8 lbs. vs. 40 lbs.
Old Jan 13, 2007 | 07:10 PM
Thinpockets's Avatar
Thinpockets
Dual mount glass spring. Way smoother ride and adjustable spring rate.
Old Jan 13, 2007 | 08:47 PM
davidbr93's Avatar
davidbr93
How difficult was the composite to install? I checked Eckler an noticed an 8 pd composite. Any drilling necessary? Unfortunately they are out of stock at the moment.
Old Jan 13, 2007 | 08:53 PM
Thinpockets
I got mine at VB&P (a supporting member) and you could install on your lunch hour. Very easy and just simple tools.
Old Jan 13, 2007 | 08:59 PM
Big2Bird's Avatar
Big2Bird
No drilling required. VB&P sells them to Eckler's.
Old Jan 14, 2007 | 07:51 AM
Ganey's Avatar
Ganey
Get the VB&P composite replacement for the spring you have. Front springs would need to be changed to use the FE-7 7 leaf for a balanced setup.
davidbr93's Avatar
davidbr93
Do VB&P have a web site? What does it stand for? I would like to do a little research. Excuse the newbie questions.
Old Jan 14, 2007 | 08:02 AM
72 LT1's Avatar
72 LT1
VB&P=Vette Brakes & Products. There on the left of main page, under sponsored ads.
Old Jan 14, 2007 | 08:05 AM
Ganey's Avatar
Ganey
Vette Brakes & Products. Sometimes referred to as VB esp. in older topics. They have been selling composite springs a long time.
Old Jan 14, 2007 | 09:14 AM
sly vette's Avatar
sly vette
What is a dual mount spring?
Old Jan 14, 2007 | 09:51 AM
Thinpockets
Dual mount allows you to adjust the spring to your preference. Also has a stabilizer effect due to the wide mount. There is no comparison between a steel spring and a composite. The glass is so much smoother you'll think you're in a different car. There are no dirty, rusty leaves to rub and squeak against each other. Even if you don't spend the extra $300 for the dual mount go with the glass rear. Small block? - Soft springs - stiff shocks.
If you really want to spend some money on suspension do the front too. I did and it's the best money I've spent on the car to date. I replaced the front coils with VB&P's kit with tubular upper and lower control arms and glass spring. I can raise or lower every corner of the car to whatever height I want. Rides GREAT!
Old Jan 14, 2007 | 11:43 AM
blctalon's Avatar
blctalon
I went through this a while back. I ended up getting a 7 leaf 2.25" HD spring (had to use 1/4" shims as they don't have this spring in 2.5") for my small block 78. I had a 9 leaf from another company that did nothing but arc out of spec and I could never get my half shafts parallel unless I used a 10" bolt which placed the spring 1/4" from the tire. I still have the large bolts installed with the 7 leaf from Vansteel, but I plan to cut the excess off once I reinstall the spare tire cover, get new exhaust, and put a full tank of gas in to see where I stand.
As far as balancing the front for the spring I used, I just replaced the springs with VB&P 460lb Grand Touring Coil Springs. The car just barely sits higher (1/4" maybe?) in the front due to the fact I went to aluminum heads, headers, and I still haven't installed my A/C. If all these things are in place you'd probably sit stock level. As mentioned the car will be leveled correctly from the back once the rest of the stuff is installed.
Old Jan 14, 2007 | 01:50 PM
Ganey's Avatar
Ganey
My balanced setup comment referred to handling.
FE-7 front is 550.
Only Performance counts!
Old Jan 14, 2007 | 06:22 PM
rudolph schenker's Avatar
rudolph schenker
To Rear Sring - 7 or 9 leaf?
