I need your help (Please) engine heat in car
Old Jan 14, 2007 | 03:57 PM
florida vette's Avatar
florida vette
Cruising
Default I need your help (Please) engine heat in car
Ok i bought this 1976 factory ac a few months ago been working on it slowly interior,brakes,radiator etc etc Im finding many things that need attention But the one that has me puzzled is
Heat from engine compartment is comming thru ac vents
I know its from engine compartment because I had valve cover leak and smoke from oil on manifolds came in ac vents allso
Probably simple but it has me stumped.
Need your input Thanks
Old Jan 14, 2007 | 03:58 PM
Big2Bird's Avatar
Big2Bird
Pull off the pass side kick panel. Check to see if this vent door is stuck open.
Old Jan 14, 2007 | 04:02 PM
florida vette
Cruising
vent door is woorking good opens and closes great
Please keep thinking thanks
Old Jan 14, 2007 | 04:16 PM
Big2Bird's Avatar
Big2Bird
Your going to get some smoke/smells anyway with the flow thru ventilation. As for heat, have you adjusted the heater door cable? Have you checked the hot water valve system?
Old Jan 14, 2007 | 04:21 PM
florida vette
Cruising
will check cable valve is new thanks again
Old Jan 14, 2007 | 04:30 PM
Big2Bird's Avatar
Big2Bird
Valve is new, good. How is switch that controls valve? Should be no vacuum at valve with cable adj right.
Old Jan 14, 2007 | 04:31 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Check the cowling seal on the rear of your hood. If it is not sealing, engine heat will enter your cabin duct work. Just put a little grease on it and shut the hood. If it's sealing, the sealing portion of the cowling will have grease on it. Good luck!
Old Jan 14, 2007 | 05:36 PM
florida vette
Cruising
ok checked all. found that vent door stays open when everything is off and when ac is on high. close in all other positions even when vent is supposed to be on?? can that be right??
Thanks again for all your help
Old Jan 14, 2007 | 06:18 PM
Kap142's Avatar
Kap142
Default Just a few un-trained thoughts....
I recently purchased a beautiful 72 454 BB. And I have noticed the same heat in the pass. compartment (but without the smoke). I am preparing to wrap all exhaust pipes with a heat wrap and plan on pulling the interior and heat shielding every square inch of the glass I can find to cut down on the intrusion, again just a thought.
Ken
Old Jan 14, 2007 | 06:21 PM
Big2Bird's Avatar
Big2Bird
That vent closes only in MAX A/C position.
Old Jan 14, 2007 | 06:25 PM
florida vette
Cruising
I wish I would have purchased a beautiful 72 454 BB
insted of ugly 76 L48
good luck
Old Jan 14, 2007 | 06:31 PM
The Spark's Avatar
The Spark
Ken
Welcome to the world of C3s. The only thing between you and the exhaust pipe and engine heat is fiberglass, carpet and relatively thin padding.
Many people put foil backed heat and sound insulation under the carpet. I'll do that when I work on my interior.
As for the exhaust in the a/c vents - as mentioned - make sure the weatherstrip is sealing off on the rear edge of the hood. The air intake for the a/c system is on the passenger side in the wiper trough (base of the windshield). If the hood is not sealing off, air will be forced out this area and right into the wiper trough.
Old Jan 14, 2007 | 06:38 PM
Big2Bird's Avatar
Big2Bird
Crawl around the plenum box. Maybe Bubba changed the heater core or evaporator, and left out the foam seals. You might even have a hole/crack.
Old Jan 14, 2007 | 06:58 PM
florida vette
Cruising
I allready installed heat shield and insulation when I installed carpet
I will replace hood seal as I have new one that came with weather strip kit it looked ok but I didnt think it did much
thanks for the info
Old Jan 14, 2007 | 08:03 PM
abs-73's Avatar
abs-73
Default Cabin Heat
Florida Vette, Did it make any difference when you installed your rad? I just changed out mine and hoping for a cooler cabin. Weather here is bad now, so I haven't had it out to see if it made a difference.
Old Jan 14, 2007 | 08:16 PM
florida vette
Cruising
Didnt change when I installed my new radiator
good luck with yours
Old Jan 15, 2007 | 09:19 AM
justanotherdoe's Avatar
justanotherdoe
Have you checked that the exterior fresh air flapper (passenger side behind wire mesh at fender with the wiper linkage) is opening and the seals around the blower motor are good? If this is closed and the kick panel flapper is closed you may be drawing air from the engine compartment through a bad fan seal. You should be able to see the fan through this fresh air intake.
To I need your help (Please) engine heat in car
Old Jan 15, 2007 | 09:29 AM
Jims79's Avatar
Jims79
Cabin heat is a problem w/all vette's. Many guys myself included install a shut-off valve in the heater core line. In the summer you shut off the flow to the heater core & shut-down the cabin heat. In the winter (if you need heat) you turn the valve on to return the flow. You can get a shut-off valve at any hardware store under $10. you will need a piece of pipe, 4 inchs long that has threads on both ends. You cut the pipe in half screw into both sides of the valve then cut your hose to the heater core, you then install the valve between the cut hose w/a clamp on each side. done no more cabin heat.
Old Jan 15, 2007 | 09:40 AM
vettfixr's Avatar
vettfixr
I published this quite a while ago and I've recommended this fix to many on the forum. Quite a few people have had excellent results performing this fix and it's cheap to do. Read the article and do a little investigating. I think you'll be surprised by the amount of heat coming into your system from this area. Good luck.
https://www.corvetteforum.com/techti...=241&TopicID=3
Old Jan 15, 2007 | 02:04 PM
VCuomo's Avatar
VCuomo
w/vettfixr!
BTW, I believe that one of the NCRS pubs (Corvette Restorer, IIRC) had a complete article, including photos, on how to make this repair.
