Drive shaft Balanced?
Old Jan 15, 2007 | 12:44 PM
Jim71Vette's Avatar
Jim71Vette
Default Drive shaft Balanced?
I think screwed myself. I removed my drive shaft to install new u-joints and forgot to mark locations on the yokes. Will I have to have the drive shaft assembly balanced? If it needs to be balanced; can anyone suggest a shop in the Atlanta area? It is for '71 270hp/auto.
Old Jan 15, 2007 | 01:46 PM
75 Hot One's Avatar
75 Hot One
OEM driveshafts are balanced so position should not be critical. To confirm, check if there are little square weights welded to the tube.
Old Jan 16, 2007 | 01:39 PM
Jim71Vette's Avatar
Jim71Vette
It has the weights welded to drive shaft. I guess It will be OK then.
Old Jan 16, 2007 | 02:35 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Typically the driveshaft & the tranny yoke are balanced as one unit. Then placement is not an issue. If you still have it out I'd have it rebalanced.
Old Jan 16, 2007 | 03:12 PM
Jim71Vette's Avatar
Jim71Vette
Thanks, now I just need to find a shop to do the balancing.
To Drive shaft Balanced?
