4L80E into a 74 Vette???
Old Jan 15, 2007 | 04:32 PM
TJP440's Avatar
TJP440
Default 4L80E into a 74 Vette???
Has anybody put a 4L80E into a C-3????
I have a handicapped customer who wants to put a 500+ HP big block into a 74 vette with a 4 spd auto (4L80E preferred due to it's strength).
He is also contemplating a paddle shifter set up. I am curious as to whether anyone here has done this swap and if so what's involved????
Thanks in advance
Tim
Old Jan 15, 2007 | 04:41 PM
mrvette's Avatar
mrvette
My '72 vert here took a tranny tunnel widening to put a 700r4 in there, but it was a muncie car to start with....I don't THINK there is a differance in the floorboards, but I had to move MINE about 1.5 inches inward down that bottom curve along the tranny housing....height wise it was fine....driver's side was fine also....had to mod the 'shoe' mount for the muncie tail shaft to take the 700.....about an inch lower and further back by about 2 inches or so....dunno about cars that are allready automatic, much less a 4L80e....
I know the 80 is a much larger/heavier tranny....about 50 lbs over a 700which is heavy enough for a vette....just not very reliable, in NO WAY to use one with a BB.....
Old Jan 15, 2007 | 04:52 PM
Durango_Boy's Avatar
Durango_Boy
The 4L80E is a truck, 4x4 transmission. Make sure you can get a 2x4 tail shaft for it.
Old Jan 15, 2007 | 05:10 PM
slowup's Avatar
slowup
its a truck tranny? I thought that they were in ls1 camaros too.
Old Jan 15, 2007 | 05:15 PM
Durango_Boy
I think the 4L60 and 4L60E were the Camaro transmissions. I could be wrong so I hope someone else chimes in.
Old Jan 15, 2007 | 06:34 PM
Little Mouse's Avatar
Little Mouse
4L80E was put in 3/4 and one ton pickups two wheel drive and probably
four wheel drive, it was the trans of choice for pulling RV trailers
of 8 to 10 thousand pounds before it was replaced with the five speed
allison.
Old Jan 15, 2007 | 06:35 PM
Durango_Boy
allison.
So there probably is a 2x4 tail shaft for it?
Old Jan 15, 2007 | 06:50 PM
Little Mouse
Yes they put it in thousands of two wheel drive pickups. When the 4L80E
quite a few yrs ago came out I was considering buying a new pickup, at that
time the 4L80E was only available in 3/4 on up pickups I don't know If they
ever offered it in a half ton later on.
Old Jan 15, 2007 | 08:13 PM
syro's Avatar
syro
Isn't it a computer controled trans?
Old Jan 15, 2007 | 08:20 PM
Durango_Boy
They make manual versions.
Old Jan 15, 2007 | 08:38 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Yes the 4L80E is electronic. Notice the E at the end lol. But it is very strong. Some of the parts will even transfer over to the Turbo 400 such as the sprag. So it is just as strong as the Turbo 400 except it has an over drive. You would go with a built 4L80E For high HP and TQ applications.
On a side note. The last time I looked into this conversion the cost was a little more than going with the TKO-600. But then again as I said the 4L80E stands above the TKO-600 when you go above 800HP. And when you get into those HP numbers most would rather concentrate on steering the beast with both hands lol.
Old Jan 15, 2007 | 08:44 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I have a 4L80 tranny in my '94 GMC Sierra Turbo Diesel (3/4 ton)
It's a heavy tranny but it's strong.. However, TH200R4's can be built stronger than a stock 4L80 (but not stronger than a "built" 4L80).
If the engine will have under 800 HP, a well built 200R4 will get the job done! I have 180 drag strip runs on my 200R4 and I'm running low to mid 10's and have 650 HP on engine!!
It all depends on who builds the tranny.. I got mine at
http://www.cpttransmission.com
That tranny has several advantages over the 4L80.. I'd only go with a 4L80 if I'd have a 800+ HP street car...
Here are some of the advantages:
1) lightest of the common overdrive trannies
2) least parasitic loss of the common overdrive trannies
3) easy bolt on installation ('79 and earlier Vettes)
Old Jan 15, 2007 | 08:56 PM
SHAKERATTLEROLL
Well there you go TJP440.
Old Jan 15, 2007 | 09:03 PM
mrvette's Avatar
mrvette
AS usual, Oliver is dead on.....
good post man....
Old Jan 15, 2007 | 09:30 PM
Durango_Boy
I didn't know it was the lightest. That's good news.
I saw an 80E for sale by an internet builder of them for one that was manual control, and didn't need a computer.
Old Jan 15, 2007 | 09:33 PM
SHAKERATTLEROLL
Durango I remember that site as well but for the life of me I just can not remember it lol. But did you look at the cost.
Old Jan 15, 2007 | 09:34 PM
GrandSportC3
I'm sure that you are talking about that one
http://www.transmissioncenter.net/4L80E.htm
To 4L80E into a 74 Vette???
Old Jan 15, 2007 | 09:37 PM
Durango_Boy
Very similar, but different company. It was still an auto...that one looks like it's a manual shift only.
Old Jan 16, 2007 | 11:40 AM
TJP440's Avatar
TJP440
Thanks for all the replies guys.
Two things that still concern me are the big ratio jump between 1st and 2nd on the 200 and 700 r4's, which the 4L80E does not share
Maybe I'm being a bit paranoid about this as the car will be a mild big block torque monster and due to the torque the ratios may not be that big of a deal
The second advantage to the 4L80 is the electronic control. The individual is handicapped and has expressed an interest in adding paddle controls.
I am hoping that somebody has done this and can give a clue as to how difficult the swap might be
Old Jan 16, 2007 | 11:43 AM
Durango_Boy
The TH200R4 has a very similar gear ratio for 1, 2, and 3 to a TH350.
