Pushrod Clearance
I FORGOT TO DO THAT!!!
Off with the intake and mask off the heads...grind away .040 on the intake side to get the recomended .060-.080 side clearance. Has anyone else had this problem with AFR heads? You put out a ton of money for these, only to modify something that should already be incorporated into a high performance big money head. Nothing short of off-set lifters or rockers would have eliminated grinding them out cause they were tight.
No trick/exotic valve train components here either...just a straight up roller cam, lifters, & rockers.
I'm not happy....Eddie
