Rear end ID / Brake question
Old Jan 17, 2007 | 09:34 AM
RedSpecialSS's Avatar
RedSpecialSS
6th Gear
Default Rear end ID / Brake question
Someone put a corvette rear into my 70 El Camino SS. Just trying to figure out what year its from. I think its an '82 but not sure.
Also, having troubles getting the rear disks off. Any advice on how to get those off?
pictures
Old Jan 17, 2007 | 09:39 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Any photos so we can try to identify it. If it's a C-3 rear end you will need to drill out the 5 large rivits to remove the disc's
Old Jan 17, 2007 | 09:43 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by RedSpecialSS
Someone put a corvette rear into my car. Just trying to figure out what year its from.
Yes pictures please...and what car? Do you know who did the work and why he did that?
Old Jan 17, 2007 | 04:56 PM
RedSpecialSS
6th Gear
bump
Old Jan 17, 2007 | 05:03 PM
Durango_Boy
Have you crawled under there to look at that red tag? It may have some useful info.
Old Jan 17, 2007 | 05:05 PM
RedSpecialSS
6th Gear
'limited slip fulid only'
Old Jan 17, 2007 | 05:07 PM
Durango_Boy
There you have it. You have a Corvette limited slip differential. J/K. Mine had the year written on it in Sharpie.
Old Jan 17, 2007 | 05:41 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Definitly from a latter C3, doesn't really matter much, they are all pretty much the same.
Like said above the rotors are riveted on, the calipers should only have two bolts holding onto the trailing arm.
Dirll the heads off the rivet heads and bang them out with punch, you will really have to smack them.
Old Jan 17, 2007 | 06:33 PM
Durango_Boy
...and no, you do not HAVE to tap and install screws. You can, but the studs and hub keep the rotor from moving around. No need to attach them.
Old Jan 17, 2007 | 06:36 PM
RedSpecialSS
6th Gear
What rivits? Well I think I see what your talking about... but not the rivits that I am use to drilling out. Those look like wheel studs going in the wrong way.
Old Jan 17, 2007 | 06:38 PM
Durango_Boy
They're called hot rivets I think. Stamped by a several ton press while they are red hot.
Old Jan 17, 2007 | 06:41 PM
RedSpecialSS
6th Gear
lovely where do I get new rivits from when I drill those out? Also any special tips to taking those rivits out? Strong drill bit? sheesh looks like this is going to be more of a job then I was anticipating.
Old Jan 17, 2007 | 06:45 PM
Durango_Boy
See my post #9. You don't have to attach the new rotor tot eh hub. The studs and hub will make sure that rotor don't go anywhere. GM riveted them in the factory because the cars were rotated ion their sides during production, and the rotors would have fallen off.
Old Jan 17, 2007 | 07:12 PM
RedSpecialSS
6th Gear
understand. Didnt see the other post. Heres a quick picture of the car in its totallity along with my other toy and now I'll crawl back you my GN and Chevelle/El Camino sites.
Old Jan 17, 2007 | 07:14 PM
Durango_Boy
Buy a Vette to go with the GN and El Camino. Then you can stick around.
By the way, you have a PM.
Old Jan 17, 2007 | 08:28 PM
Gordonm's Avatar
Gordonm
Judging by the aluminum bat wing you have a 80-82 rear from a Vette. Unfortunatly they are the weakest ones. You can bolt in a older pre 80s cast iron one for more strength but the 80-82 is a weak link.
Old Jan 27, 2007 | 01:09 PM
Durango_Boy
I never would have guessed the aluminum from late C3 would be weaker than the iron mid C3 setups.
To Rear end ID / Brake question
