Recalibrating 77 Tach
Old Jan 17, 2007 | 12:00 PM
spanishsilver's Avatar
spanishsilver
Default Recalibrating 77 Tach
Is there a way to recalibrate the tach on the 77. I have all gages out and tach still reads 1800 RPMs. When it was in the car it would reset to 500RPMs with car idling. After I would shut it off it would read 1800 hmmm. Any ideas?
Old Jan 17, 2007 | 12:09 PM
Durango_Boy's Avatar
Durango_Boy
May be a bad tach board, and it may be a bad filter at the distributor.
Old Jan 17, 2007 | 12:10 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
These tachs will not read zero with the ignition off. My '76 shows around 700. Once the ignition is turned on, it should go to zero and, of course after starting the engine, it should show the proper RPM.
Old Jan 17, 2007 | 12:13 PM
Jud Chapin's Avatar
Jud Chapin
Take a look at this:
http://www.corvettemagazine.com/2006...meter_tach.asp
Old Jan 27, 2007 | 01:02 PM
Durango_Boy
My '77 tach reads zero with the ignition off. It'll jump when I start it, but it's zeroed every other time.
Old Jan 27, 2007 | 02:58 PM
Jud Chapin's Avatar
Jud Chapin
Does your tach show the proper RPM with the engine running?
Old Jan 27, 2007 | 02:59 PM
Durango_Boy
Yeah, perfect. Right about 700 at idle, 500 in gear, and a smooth arch upward as I push the accelerator.
Old Jan 27, 2007 | 03:06 PM
Jud Chapin's Avatar
Jud Chapin
Well, I guess I've never seen one of these '75-'77 electronic tachs that zeroed out with the ignition off. Even the repair article I referred to above indicates one of the signs of trouble with these tachs is when they don't return to zero when the ignition is turned on. Anyway, I guess there's a first time for everything.
Old Jan 27, 2007 | 03:08 PM
Durango_Boy
Maybe mine's odd. Now, my red '77 had a tach needle that was usually near 4000 when it was off, but my blue '77 zeroed too.
Old Jan 27, 2007 | 03:13 PM
Jud Chapin's Avatar
Jud Chapin
As long as it works with the engine running...who cares what it reads when it's shut down, right?
Old Jan 27, 2007 | 03:14 PM
Durango_Boy
Exactly.
Old Jan 27, 2007 | 03:19 PM
Jud Chapin's Avatar
Jud Chapin
Exactly.
As an aside, did you ever get that C4 blower motor set up in your C3? I'm kinda waiting to see how you make out.
Old Jan 27, 2007 | 03:24 PM
Durango_Boy
It'll be fine as soon as I make the spacer. I've tried wood, and they crack to easy. I tried a plastic cutting board, but it melts badly and any saw blade gets stuck. It would have taken forever. I'm looking for a new material now.
Old Jan 27, 2007 | 03:28 PM
Jud Chapin's Avatar
Jud Chapin
Please keep us posted. Jud
Old Jan 27, 2007 | 03:29 PM
Durango_Boy
Oh I will. I will make sure everyone who was interested has all the details.
Old Jan 27, 2007 | 03:31 PM
Jud Chapin's Avatar
Jud Chapin
You da man!
Old Jan 31, 2007 | 01:53 PM
Durango_Boy
You da man!
Any ideas for material? Light, strong, easy to cut with a jig saw, and cheap to buy locally.
To Recalibrating 77 Tach
