How noisy is a cat ??
Old Jan 17, 2007 | 04:19 PM
hensen1954's Avatar
hensen1954
Default How noisy is a cat ??
Thrown my 81 cat in the bin - and about to choose a dual system and was just wondering if the cat had any noise reducing qualities as well as power reducing ones ??
Old Jan 17, 2007 | 04:21 PM
JustinD's Avatar
JustinD
Cats quiet it down considerably and also double as a power reducing device. What a wonderful addition to a performance car huh.
Old Jan 17, 2007 | 05:00 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
They can be pretty noisy if they are pissed!
Old Jan 17, 2007 | 05:05 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Originally Posted by JustinD
Cats quiet it down considerably :
I have to disagree. I once had a 80 4/speed and put some
high flow cats (DUAL) with some flowmasters, true duals
and that BIACTH was LOUD
Old Jan 17, 2007 | 05:22 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Old Jan 17, 2007 | 05:34 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I spent a lot of time on this one......the cats will act as additional mufflers even high flows. The high flows will allow your exhaust to be more "rumbly" but still tone down the volume some. To get the true 60s rumble you have to get rid of the cats, but where I live that makes you non-EPA compliant and you won't pass the test. For that reason I put the high flows. The exhaust sounds good now.
Old Jan 17, 2007 | 05:43 PM
OregonVette80's Avatar
OregonVette80
High performance cats will not decrease hp.
The new Z06 2007 Vette kicks out over 550RWHP. It has 4 cats.
-Just sayin
Old Jan 17, 2007 | 05:59 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Just replacing the factory cat on my white 79 with a "test pipe" improved the exhaust sound considerably. Don't need emissions testing where I live but I could always easily return the cat if needed.
Old Jan 17, 2007 | 10:37 PM
dgruenke's Avatar
dgruenke
That's a great picture.
As far as the catalytic converter is concerned, when I took mine off of my 1976 and went to true duals, it was like night and day. It was too quite with the cat.
Old Jan 17, 2007 | 10:41 PM
Shark Racer's Avatar
Shark Racer
-Just sayin
~440 rwhp, and I THINK it only has 2 cats but don't quote me on that. You can quote me on the RWHP though. 505 at the crank.
I see no reason NOT to run cats, it's a $200 investment and a huge relief on the environment. Lose about 5 hp but give back to everyone in the world.
Old Jan 18, 2007 | 12:22 PM
C3 4ME's Avatar
C3 4ME
My 81 Z28 that I used to have a 2 into 1 back into 2 exhaust, where it went to 1 pipe to go through the converter. That car had no mufflers when I got it, but I added them and the noise level hardly decreased, so the cat was obviously doing the bulk of the sound deadening.
Old Jan 18, 2007 | 12:25 PM
OregonVette80
[QUOTE=Shark Racer;1558562856]~440 rwhp, and I THINK it only has 2 cats but don't quote me on that. You can quote me on the RWHP though. 505 at the crank.
QUOTE]
Nope. It has 4 cats. I saw the z06 do 550+ at the rear with my own eyes at our Vette Dyno Day. I'll post the dynosheet. It's on the Pacific NW board titled "Dyno Day results." Granted, you are somewhat correct, it is NOT straight from the factory, but...it's just a slight "tuning" at a tuner shop with slight mods.
Pretty amazing.
You'll notice, that it reads "stock" the only tweeking done was "tuning" of the beast. There is NO SuperCharger, no nitrous.
-From the thread.
Once we have the dyno video uploaded I will post it as well. Mind you these numbers were made through the STOCK MUFFLERS! Of course I added a new set of header to the combination, but the owner wanted it quiet, I did however add a bypass switch for the Bi-Mode exhaust system so that he can open the exhaust valves manually at his will. All in all it was a fun day.
http://forums.corvetteforum.com/show...no+day+results
Old Jan 18, 2007 | 08:57 PM
shafrs3's Avatar
shafrs3
I'm retrofitting them to my '72 now.
To How noisy is a cat ??
