removable rear window in a 76 coupe.
Old Jan 17, 2007 | 07:42 PM
36chambers's Avatar
36chambers
Default removable rear window in a 76 coupe.
hello i am converting my vette from a fixed rear window to a removable one like the 68-72 models and i need some help. i have purchased most of the parts involved. window (w. frame, and pins), weatherstrip, locks, pin guides and wedge plate. i want to know if this jop is possible to do without the ceiling panels or the lower window trim. i have heard that you can just cut the lower trim and that the locks can be just screwed into my original ceiling panels. please advise with answers or any advice on the process thanks in advance.
Old Jan 17, 2007 | 07:46 PM
Durango_Boy's Avatar
Durango_Boy
I'm pretty sure it'll work a lot better if you cut out both the upper and lower trim sections. Here's a tip though, when you glue up the seal, put the window in and latch it. That'll ensure a proper fit, and you'll see any problems before the glue has cured.
Old Jan 17, 2007 | 08:13 PM
GaryS's Avatar
GaryS
There should be a lot of information on this in the archives. I recall seeing this several times (and even commented on it once) and in some of those posts they give very detailed instructions.
Gary
Old Jan 17, 2007 | 09:46 PM
36chambers's Avatar
36chambers
Default i have reviewed the posts....
but i still want to hear from people who did the install w. out ceiling panels or lower trim from a 68-72. thanks
Old Jan 17, 2007 | 11:49 PM
Artsvette73's Avatar
Artsvette73
I diden't cut the lower trim at all and I don't see a reason to. The uppers would have to be cut out for the latches. Or find an early set of halo panels.
Old Jan 18, 2007 | 12:22 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What they said. Either cut your panels and find a set of the '68 bezels (ZIP stopped carrying them, Dr. Rebuild might have them), or get a set of the 69-72 molded panels. The lower trim should be the same. Obviously, the plastic bezel around the window is tossed out.
Old Jan 18, 2007 | 09:10 AM
ajstr1265's Avatar
ajstr1265
I did not cut my lower panels and I am looking for upper panels, I hate to cut good ones. Although I think I saw on previous posts that there is trim you can install around the latches after you cut the panels. It looks like a small plastic trim to cover the rough edges. Is this factory?
BTW this is the best thing I did to mine!
Old Jan 18, 2007 | 10:15 AM
Durango_Boy
I got some panels that have the cutouts, so I could offer mine up to someone wanting to cut theirs. Keep in mind that mine were wrapped in a red velor for about a decade, so they're covered in upholstery glue.
Old Jan 18, 2007 | 11:57 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yep, the trim is factory. 68s and maybe early 69s and straight-cut panels and an insert bezel. 69-72 used a halo panel that had the notch and step molded in.
Old Jan 27, 2007 | 01:16 PM
Durango_Boy
I can't tell which these are. They look nice and are original, but I have no idea what year they are.
Old Jan 27, 2007 | 03:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If they're the ones that you showed me the picture of, they're the 68-69 type that use the separate bezel.
Old Jan 27, 2007 | 04:00 PM
Durango_Boy
Hmm...who sells that separate bezel?
Old Jan 27, 2007 | 05:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
They aren't in ZIP's catalog anymore. You might try calling Dr. Rebuild. Other than that, check eBay or put an ad in "parts wanted."
Old Jan 27, 2007 | 07:18 PM
Durango_Boy
Heh heh...I'll call Doc, and say I'm from Zip and mess with him a little bit.
To removable rear window in a 76 coupe.
