Bell housing question
Old Jan 18, 2007 | 03:59 PM
Lee H's Avatar
Lee H
Default Bell housing question
Which bell housing do I need? I am collecting parts for my 75 auto to 4 speed convertion. I have most parts and I am honing in on the balance. On of the few parts I still need is a bell housing. Can some one please provide me with the GM part number? I have an M21 and a L88 fly wheel which will use a 10.5 clutch. Thanks, Lee
Old Jan 18, 2007 | 04:32 PM
jerome1979's Avatar
jerome1979
Originally Posted by Lee H
............... a L88 fly wheel which will use a 10.5 clutch........
L88 have 11' clucth i belive!
so if you want stock style take a 621 bellhousing
but other number exist! just take a car bellhousing and not a truck bellhousing because on truck have less precise bore to guide gear box!
Ps: correct me if i'm wrong
Old Jan 18, 2007 | 04:39 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Oddly enough, I believe L-88 and and ZL-1 clutches were the smaller 10.5 incher,..but I believe they used the dual-disc clutches which would have provided more surface area than the 11" clutch and obvously the smaller flyweel saved some weight.
I'm sure somebody can expound.
Old Jan 18, 2007 | 05:03 PM
Ironcross's Avatar
Ironcross
The L88`s used a lightweight 15 Lb flywheel and a 10.5 diaphram pressure plate with a single disc.
Old Jan 18, 2007 | 05:16 PM
redvetracr's Avatar
redvetracr
I`m sure someone will post more numbers but you can use the #403 or #383....NO reason to pay a premium for a #621 or a #444
...redvetracr
Old Jan 18, 2007 | 05:45 PM
willem wallace's Avatar
willem wallace
Default Automatic Set-Up
Hi Lee,
Not to change the context of your post, but I am searching for a good deal on an automatic shift set up for my turbo 400. I need pretty much the whole set-up, from shifter to transmission. Will you be selling these parts?
To Bell housing question
