QUICK EASY QUESTION
Old Oct 2, 2001 | 06:53 PM
VolVette's Avatar
VolVette
Default QUICK EASY QUESTION
What are symptoms of a bad PCV valve? Would stalling be one?? Is there any way to check to see if mine is ok?
Thanks, as always!
Cheers,
Stephen
daily_driver's Avatar
daily_driver
Default Re: QUICK EASY QUESTION (VolVette)
take it out and BLOOOOOOOOOOOOOOOOOOOOOOOOOWWW!!
hahahah
now look in the mirror for an oil ring around yer mouth
hahahahahah
:jester :jester :conehead :conehead
Old Oct 2, 2001 | 07:50 PM
73Ken73's Avatar
73Ken73
Default Re: QUICK EASY QUESTION (daily_driver)
I don't think that your engine would stall due to a clogged PCV. You can check it by shaking the valve an see it the ball is loose. If the ball is loose then the valve is probably okay.
Old Oct 2, 2001 | 08:19 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
hahahah
hahahahahah
ROTFLMAO -- seen that one done !!!
Yep, shake it to see if it still rattles. Also while the engine is running at idle, there should be vacuum at the end of the valve. If you rev the engine / snap the throttle, the valve should temporarily close.
The design of the system is so that it is only drawing from the engine at high vacuum situations such as idle and deceleration.
I have not seen a PCV cause problems with the car running, but you could always plug the line and test it. DO NOT drive around too long with no PCV, ie don't plug the valve cover.
To QUICK EASY QUESTION
