Depressed / Sunken Headlight
Old Jan 18, 2007 | 07:44 PM
avijay's Avatar
avijay
Default Depressed / Sunken Headlight
Any idea how to even this out. It's very minor but I notice it and was wondering if there is a way to even it out flush a little bit better. The drivers side headlight is very slightly sunken by millimeters but if you guys can give me any tips on how to fix this that would be great. Hopefully the pics may help
[IMG]
[IMG][/IMG]
[IMG][/IMG]
Thanks.
Old Jan 18, 2007 | 08:03 PM
sly vette's Avatar
sly vette
There should be a threaded rod under the headlight assy. that will have a 5/16 or 1/4"hex head on it. try adjusting that.
Old Jan 18, 2007 | 08:25 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
please do not get depressed over a sunken headlight.
life is too short.
Old Jan 18, 2007 | 08:27 PM
avijay's Avatar
avijay
Haha I guess I had that coming with the title I gave it. Good one.
Old Jan 18, 2007 | 10:23 PM
wombvette's Avatar
wombvette
yep, the little threaded adjuster with the small hex head. Only problem is that it is through pot metal and is likely to be frozen.
Old Jan 19, 2007 | 12:15 AM
Artsvette73's Avatar
Artsvette73
You will be lucky if it's not frozen. Becarefull they do snap off.
Old Jan 19, 2007 | 05:20 AM
Rotonda's Avatar
Rotonda
The front edge of the entire headlight assembly rests on a metal channel. It is retained by 2 dolts through this channel, 1 on either side. Remove these 2 bolts and place shims between the top of the channel and the underside of the 2 ears of the headlight assembly which rest on the ledge. This will get you a perfevt vertical alignment.
Old Jan 19, 2007 | 06:55 AM
avijay's Avatar
avijay
All great tips, thanks. I will be working on this Saturday and let you know how it goes. Thanks again.
Old Jan 19, 2007 | 08:26 AM
BB72's Avatar
BB72
Default Keep in mind
that you could also have the tabs broken off the front of your horse shoe. It happens...with our cars riding so rough. There is also a few other adjustments. Look at mine and you can see where.
Try to see on mine, there is a bracket. It has the two outer(larger) springs connected to it at the backside, bolted to the housing. You can see the 2 outer bolts holding it down. This bracket slides back and forth for even more adjustment. Keep in mind there is another bolt in the center. Looking at the pic I think you slide it back to raise the assembly, forward to lower it.
Old Jan 19, 2007 | 11:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You shouldn't have to go to all the trouble of shimming the headlight support; adjustment is from underneath as previously stated.
Old Jan 19, 2007 | 01:17 PM
avijay's Avatar
avijay
Anyone have a pic of the threaded rod under the headlight assembly with the hex adjustment on it??
Old Jan 19, 2007 | 01:51 PM
72LS1Vette's Avatar
72LS1Vette
Take a look at the support bar that holds the headlight assemblies to make sure it isn't coming loose from the nose. I would use PB Blaster daily for at least a few days on any nuts or bolts that you want to turn. The pot metal corrodes really badly on the headlight assemblies.
Rick B.
Old Feb 4, 2007 | 03:44 PM
avijay's Avatar
avijay
Default Thanks
Thanks to all that gave me the great advice, I finally got around to working on the light assembly and the hex screw worked great on getting the lights flush with the body. It look great now. Thanks.
To Depressed / Sunken Headlight
