"Venting" L88 hood???
Old Jan 21, 2007 | 03:36 PM
  #41
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by Durango_boy
I would love to speak with one of those guys who knows the dynamics to that hood. I would love to work with him to design a way to get the hot air out and more cold air in. I have an L88 with no air box, so the pressure difference at the windshield is no big deal to me.
You lost me on the last sentence there. I'm not sure what you're getting at. Regardless of whether you have an airbox or not, the pressure at the windshield base works the same to induce cold air into the scoop (and the air filter if it's open at all towards the distributor).
Old Jan 21, 2007 | 04:50 PM
  #42
kaiserbud's Avatar
kaiserbud
I got my L-88 hood for $330 from the GM dealer ... in 1976
I see the vent only working during low speeds or while in traffic. Since hot air rises, this sounds like a good idea. It seems like it would have little affect on the temp of 'cold' air at rear of hood. Even if it did - what differential? Certainly venting 300? degree heat would be better than keeping it. Also, how much of that vented hot air would actually enter the back of the hood - its not like it channeled or piped directly into the back of the hood. The cold air intake is sealed and intentionally so to prevent this extremely hot air from entering the carb. If you are travelling at x speed, I would assume the vented hot air would be even less of a problem.
Aerodynmaics would be cool to see - hey - maybe it would roll off to the sides due to the hood design??
Some negatives might be Rain/Road water and debris can drip/drain onto engine. Or when washing, water could pour onto hot engine.
Last edited by kaiserbud; Jan 21, 2007 at 08:28 PM. Reason: changed the word crap to debris
Old Jan 21, 2007 | 04:57 PM
  #43
kaiserbud's Avatar
kaiserbud
Originally Posted by 69427
... Regardless of whether you have an airbox or not, the pressure at the windshield base works the same to induce cold air into the scoop (and the air filter if it's open at all towards the distributor).
I would assume there is a difference, because with the sealed air filter would create somewhat of a 'void' at teh back of the hood and enhance the differential in pressures. Whereas without the sealed cold air chamber, air is flowing right on through and OUT the back of the hood - most likely not in. Also - the air filter is open all the way around on the carb when using an L-88 FResh Air Package Hood - not just towards the back/distributor.
I am really starting to see how sealing your car is so advantageous to cool your car.
Old Jan 21, 2007 | 09:18 PM
  #44
69427's Avatar
69427
Originally Posted by kaiserbud
........................................ . Whereas without the sealed cold air chamber, air is flowing right on through and OUT the back of the hood - most likely not in. Also - the air filter is open all the way around on the carb when using an L-88 FResh Air Package Hood - not just towards the back/distributor.......
No. Try hanging a couple of pieces of tape or string down the back of the scoop. When you're travelling down the road (or the track, more importantly), the air does NOT go "OUT the back of the hood". It reverses direction when it hits the windshield and goes INTO the scoop. I'm quite well aware of the construction of the L-88 cold air inlet system. Even without the seal around the top of the carb area, the high pressure area at the base of the windshield still moves cold air towards the air filter. My point was that an open element air filter (like most of us run in late 60's/early 70's big blocks) will end up pulling cold air from the distributor area, along with some warm air from the front (radiator side) of the filter. Not as good as a sealed system, for sure, but definitely an improvement over pure underhood air.
Old Jan 21, 2007 | 11:10 PM
  #45
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
All of this was hashed out several times over the past few years. Below is a link to a good discussion. Happy reading.
Thread on Aerodynamics
Old Jan 22, 2007 | 11:20 AM
  #46
Durango_Boy's Avatar
Durango_Boy
But I don't have any scoop. The engine is sealed from the outside when considering the hood. No opening at the front or back, sealed all the way around. The pressure at the base of the windshield makes no difference because it's not gonna have anything to do with what air goes into the motor. I was thinking if I cut a vent into the dip in the hood, it might suck hot air out. Others say that affects what air is sucked into the bay for the engine at the cowl, but I don't have a cowl opening.
Old Jan 22, 2007 | 02:55 PM
  #47
redvetracr's Avatar
redvetracr
If your L-88 hood isn`t open at the rear it`s not an L-88 hood.
...redvetracr
Old Jan 22, 2007 | 03:04 PM
  #48
69427's Avatar
69427
...redvetracr
If it's not open to the outside world, what's the point? Sounds like there ought to be a cheaper way to keep the rain off your engine if that's all your hood does.
Old Jan 22, 2007 | 03:09 PM
  #49
Durango_Boy
Well it looks cool and gives me more clearance than the stock hood.
Old Jan 22, 2007 | 03:15 PM
  #50
redvetracr's Avatar
redvetracr
I`m confused.....and more than usual!! Your L-88 hood is NOT open at the rear??
...redvetracr
Old Jan 22, 2007 | 03:16 PM
  #51
Durango_Boy
...redvetracr
I laid it on the car to test fit it when I got it, and was wondering if I were going to use the stock style hood sealing kit because the back wasn't open like I was expecting.
Was it laid incorrectly?
Old Jan 22, 2007 | 03:45 PM
  #52
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
All of the aftermarket L-88 hoods that I've owned or seen for that matter, had a solid cross-member across the back. To use the airchamber or take advantage of cowl intake, you had to make openings in the cross-member.
Dave
Old Jan 22, 2007 | 03:47 PM
  #53
VETTEVIC's Avatar
VETTEVIC
No, you have to cut out the back for air to get in at the cowl. They do not cut them when they are made in case you want to have the forward air entry like the later cars come with, where it draws air over the radiator to ducting to the carb.
Old Jan 22, 2007 | 04:02 PM
  #54
Durango_Boy
Good I was beginning to think I was a little crazy.
Old Jan 22, 2007 | 09:26 PM
  #55
BigBlockk's Avatar
BigBlockk
I've seen some here wondering where high and low pressure areas are around the hood. Why don't you use a manometer to find them?
BigBlockk
Later.....
Old Jan 22, 2007 | 09:40 PM
  #56
kaiserbud's Avatar
kaiserbud
It reverses direction when it hits the windshield and goes INTO the scoop. .. the base of the windshield still moves cold air towards the air filter. Not as good as a sealed system, for sure, but definitely an improvement over pure underhood air.
I hear what you are saying .... but is that cold air induction - or just turbulance that brings air into the rear of the engine compartment and down the front of the firewall? Sure - its better than closed hood temperatures - but I wouldn't say it is cold air induction
Durango Boy - I have seen the L-88's with the closed rear area.
Old Jan 22, 2007 | 11:39 PM
  #57
69427's Avatar
69427
If it is non-heated, ambient temperature air (i.e. cold air) and it's being inducted into the engine compartment and air filter area, that's cold air induction in my book.
To "Venting" L88 hood???
Old Jan 23, 2007 | 08:20 PM
  #58
VETTEVIC's Avatar
VETTEVIC
Does anyone have a pic of the factory l88 cowl air door?
Also, on the same lines as the L88 venting, isnt the factory LT1 hood vented?
Old Jan 23, 2007 | 09:39 PM
  #59
kaiserbud's Avatar
kaiserbud
the LT-1 hood had no vents - just chrome inserts for looks in those two areas. As for a door for the L-88 hood - there is none I am aware of - they are always open at the rear htat tunnel into the sealed area around the carb
Old Jan 23, 2007 | 10:34 PM
  #60
gyopp's Avatar
gyopp
When I get my car back together I am going to test the cold air induction theory by temporarily installing a thermistor temp sensor inside the air breather. I will seal the rear of the hood and check temp then run again with it open and compare the results. It will probably be a month from now but I will post the results
