So here is what I am thinking
Old Jan 19, 2007 | 08:20 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default So here is what I am thinking
KB100 pistons with their 7cc flat top pistons will make a nice 10.865 to give me a sweet 8.211 dynamic compression ratio with my 288/300 cam. These will promptly be sent to Swaintech for low friction skirt coatings and a thermal barrier.
The strongest 5.7" I beam rods Scat makes. These will also be on their way to Swaintech for an oil shedding coating.
A scat 9000 383 crank, with the 1 pc rear main seal. Also to be treated with an oil shedding coating. I have a good sized kickout the length of my oil pan designed to catch the oil and keep it away from the crank. So this is a fortuitous alignment of the stars.
I havent really figured out my piston ring situation.
What should I get? Is there a definable benefit to the thinner rings?
Old Jan 19, 2007 | 11:16 PM
jackson's Avatar
jackson
No offense intended, but with exception of factory skirt coating, I think expensive coatings of budget rotating assembly in a street motor is waste of good $resources$.
Standard ringpak is fine. However, thin AND shallow rings are a good thing if coupled with a straight & stable bore ... most today's vehicles have them OE; ie 96-up iron vortec have 1.5mm,1.5mm, 3mm ringpak that're also shallow (lower tension) ... done right, they work great for a long time & w/ less friction.
FYI: KB100 sits only 0.017" below stock deck; most pistons sit about 0.025" below.
-edit- FM/sealedpower/speedpro P/N H860CP is virtual equivalent of KB100 but comes with skirt coating & I've seen em on ebay ( seller racersoutlet ) for about $175/set. -5cc, 1.425"cd, flattop w/2vr, press or float, std ringpak. I much prefer sp design & quality over kb.
Frankly, I'd go w/ 6" rods and sp P/N H124CL ... skirt-coated, flattop, 2vr, 1.130"cd, -5cc, 1/16,1/16,3/16 ringpak, press or float ... same ebay seller gets about $225/set. Typically, 6" setup ends up lighter than 5.7 ... & easier to balance.
Old Jan 20, 2007 | 07:18 AM
Guru_4_hire
Cruise-In V Veteran
The problem is that the 2cc makes a BIG difference. 7cc versus 5cc.
8.4:1(5) dynamic versus 8.2:1(7) dynamic compression.
I really need to cc my heads though.
Maybe instead of buying all that stuff I will have my heads flowbenched and my chambers cc'ed. That could be fun too.
About rods. from what I understand 6" rods need more notching around the block.
I am going to be working on this motor for awhile, so neat stuff is fun.
I am going to use the distributer I rebuilt with the crane XR-i and put it in my existing L82 and run that till this motor finally comes together.
Old Jan 20, 2007 | 09:47 AM
shafrs3's Avatar
shafrs3
I agree with the coatings theory, that money could be used towards something with greater benifits.
Old Jan 20, 2007 | 10:03 AM
Guru_4_hire
Cruise-In V Veteran
Present options. I am open to ideas.
I am going to run manifolds for reasons other than horsepower gain. When I finally get around to getting headers, I am going to change camshafts and have custom headers made with a burns stainless collector with the venturi. Till then its manifolds.
I dont see any reason to invest in lightweight parts. At least not selectively.
Old Jan 20, 2007 | 11:51 AM
gkull's Avatar
gkull
Right off the Swain site they talk about oil repellant coatings only coming into play over 6000 rpm. So it could be a cost per hp item.
As for rings. The width of the piston lands determine the width of the piston rings. Total seal rings are a good product.
As for rod length determining block grinding amount It's not true at all. The design of the rod is the determining factor. It is the rods big end bolt that has to get clearanced. Big 680 gram Manley H-beams like I have been using are probably the worst case. Smaller sub 600 gram I beam rods need much less clearancing.
The Morroso diamond crank stripper is a good item in lou of oil repellant crank/rods/under side of the pistons.
Old Jan 20, 2007 | 12:18 PM
Guru_4_hire
Cruise-In V Veteran
I am definitely interested in this crank stripper. Got a link.
Per chance did you mean milodon?
Its not about the money. But you make a valid point about the over 6000 rpm thing.
Old Jan 20, 2007 | 12:50 PM
gkull's Avatar
gkull
I just remembered the M so you are right. Milodon
http://store.summitracing.com/egnsea...115+4294856935
The later L-82's came with a factor stripper. The after market just made copies after the factory
Old Jan 20, 2007 | 12:53 PM
Guru_4_hire
Cruise-In V Veteran
Coolio
That will work.
I have this neat little oil pan with a huge kickout the entire length of the oil pan to keep oil away from the crank as it gets thrown off. Pretty cool.
Old Jan 20, 2007 | 03:25 PM
gkull's Avatar
gkull
You will need these.
http://store.summitracing.com/partde...part=MIL-81150
Old Jan 20, 2007 | 03:34 PM
Guru_4_hire
Cruise-In V Veteran
I was going to get main studs for windage trays.
To So here is what I am thinking
