Water Pump Install Question
Old Jan 19, 2007 | 08:33 PM
DO2G's Avatar
DO2G
Default Water Pump Install Question
Do I need to put any RTV on the threads of the water pump mounting bolts?
Old Jan 19, 2007 | 08:54 PM
Bob3700's Avatar
Bob3700
Default Sealer
Normally, you put a non-hardening sealer like Permatex on those threads.
Bob
Old Jan 19, 2007 | 09:07 PM
Glassbowtie77's Avatar
Glassbowtie77
I put teflon tape on mine and have had no problem with leaks.
Old Jan 19, 2007 | 09:25 PM
rk73's Avatar
rk73
Default water pump
I use a small amount of RTV
Old Jan 19, 2007 | 09:30 PM
SIXFOOTER's Avatar
SIXFOOTER
RTV
Old Jan 20, 2007 | 12:05 AM
68RATVT's Avatar
68RATVT
I use a permatex silicon thread sealer, not rtv, if you use rtv make sure it's set before adding fluids....
Old Jan 20, 2007 | 11:58 AM
TimAT's Avatar
TimAT
I'd just use some pipe thread sealer. RTV is fine, but once it sets and you have to remove the pump again, you need to clean up the old RTV. With the pipe sealer, just reapply and go..
To Water Pump Install Question
