Torque specs, anyone know?
Old Jan 20, 2007 | 02:31 PM
1ARACE's Avatar
1ARACE
Default Torque specs, anyone know?
Steering knuckle, 15/16" bolt (runs thru dust shield and caliper mounting bracket) and the two lower 3/4" bolts (runs thru dust shield, steering arm and caliper bracket).
Been thru AIM and repair manual and I cannot find torque specs on these.
Thank you.
Old Jan 20, 2007 | 06:09 PM
blctalon's Avatar
blctalon
"spindle bolt torque" in the search will yield some results, but to save you the time, the upper big bolt is 75-85ft/lbs. I did mine at 75lbs. I don't recall the bottom ones, but I think I did around 50lbs - you might want to dig deeper for the torque on those. Maybe someone will post that knows.
