Garage floor paint?
Old Jan 23, 2007 | 01:09 AM
Taijutsu's Avatar
Taijutsu
Default Garage floor paint?
Forum: What is a good paint/coating for my garage? Epoxy is out $485 ?
What are my other options for a no peal/chip floor? Is $200 unreasonable? TIA
Rick
Old Jan 23, 2007 | 09:25 AM
wackywitch's Avatar
wackywitch
Default garage floor paint
I did both my garages with Rustoleum EPOXY PAINT with non skid sprinkles for less than 50.00 a gal. 2 gal. did my 30X40 garage. The epoxy comes in blue and brown color. Its been on my floor for 3 years and still looks great. It gets alot of abuse also.
George
Old Jan 23, 2007 | 10:42 AM
Duke94's Avatar
Duke94
George
I used the Rustoleum Latex epoxy paint as well. Got it on sale at Lowes for I think 32 bucks a gallon. Took 2 gallons to do my 24x24 garage. It held up well to hot tires and chemicals. Only place it came off was where I dragged an engine block across it. Can't beat it for the $$.
Old Jan 23, 2007 | 10:57 AM
SoCalErv's Avatar
SoCalErv
Army
Pianted garage floors look great. However, remember that once you put it on, like a wedding ring, you are married to it. That means maintenance, etc.
Old Jan 23, 2007 | 11:52 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Rick
Rustoleum kits are about $50 each....each kit will do a single car garage. Good Stuff.
Old Jan 23, 2007 | 12:48 PM
C3 4ME's Avatar
C3 4ME
my brother did I think the rustoleum also in his garage. He's not a car guy at all, but the garage is a daily use garage, 2 cars in and out every day and it's been down for a few years with no problems at all.
Old Jan 23, 2007 | 01:11 PM
GM73VETTE's Avatar
GM73VETTE
Default Garage Floor Paint
I have a 4 car garage and like the looks of concrete.
I cleaned the floor real good with muratic acid, 1-10, lots of water on the clean up.
Mixed Min Wax Exterior Poly Varnish about 1-4 with mineral spirits, rolled it on.
Keeps the dust down easy clean up and touch up if needed. if gasoline is spilled, recoate.
This is a lot less mess than paint.
gm73vette
Old Jan 23, 2007 | 03:28 PM
flttester's Avatar
flttester
Love my epoxied floor. Durable, easy clean up and looks good. I'd stick with a two part epoxy and like any paint project, preparation is everything.
A lot of good info on garagejournal.com to help make your decision.
Old Jan 23, 2007 | 03:36 PM
Frank O'Hara's Avatar
Frank O'Hara
I've used a few different types of epoxy garage paint. I've had the best luck with the paint from Griots Garage.
http://www.griotsgarage.com/catalog.jsp?&SKU=90011
Old Jan 23, 2007 | 04:13 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have you looked at the various types of tile. I used epoxy about 7 years ago and I have the hot tire problem where the paint comes up. This is something you don't have to worry about with tile.
Old Jan 23, 2007 | 06:05 PM
Frank O'Hara
I have had that happen with other garage epozy paints - The Griot's floor paint is like nothing I've seen before - ZERO lifting after 4 years.
Old Jan 23, 2007 | 08:04 PM
philbshelb's Avatar
philbshelb
i put durall on 2 years ago. 2 part epoxy no problems
Old Jan 23, 2007 | 08:14 PM
Green73's Avatar
Green73
I strongly recommend AGAINST Behr's one coat epoxy. I put it down on my floor and have not been impressed with it at all. I did all the prep work that was on the label. Washed, degreased, etched, primed and put two coats of the paint down and then a top coat of high gloss sealer. (all Behr's products). I even parked everything outside for 14 days as the labels indicated. Pulled in the garage and the first time I left the tires pulled up the paint down to the concrete. It will repel oil but only for a VERY short period. After the oil is there a day or two, the oil still comes up but the floor is badly stained. Very dissappointing. Next time I will look into Sherwin Williams two part product.
Old Jan 23, 2007 | 08:36 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I responded to your other thread in 'general' - I used the HD paint, I think it's Behrs and had no problems.... heck, it's less than $25 a gallon, at that price I don't mind touching up once a year
BTW, I have to re-paint it anyways....the epoxy is about 16 months old .... somehow the floor turned blue .... I noticed shortly after I painted my car
Old Jan 23, 2007 | 09:11 PM
Witz's Avatar
Witz
I was going to spend about $1000 on U-Coat "professional grade" epoxy, but decided to spend $160 on Quickrete two stage epoxy. This stuff is strong and comes in many colors. The key is preparation - one spec of oil or grease will ensure something will lift. I park my cars on 2x2 rubber matts just to be safe (to prevent hot-lifting).
I have dropped wrenches from 5 feet and actually dropped one of the four hundred pound ramps from my lift (when I was unpacking it) and it put the smallest of scratches in the floor. The garage stays spotless now, I just mop the floor.
Old Jan 23, 2007 | 10:19 PM
mrvette's Avatar
mrvette
There is NO floor coating as durable and trouble free as concrete....
CASE CLOSED......
yeh, sure they can paint dealerships up nice and pretty....guess who's paying for it???
Old Jan 23, 2007 | 11:09 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I had a high dollar epoxy floor put in and if all you are going to do is have a pretty garage go for it. But if you are going to build engines, cut steel, fabricate, weld etc. It's not worth it. I don't think I'd do it again. Ron B.
To Garage floor paint?
Old Jan 24, 2007 | 05:49 AM
Jud Chapin's Avatar
Jud Chapin
Did you put the Groit product right over the epoxy?
Old Jan 24, 2007 | 09:41 AM
spedaleden's Avatar
spedaleden
I went with U Coat it. Spent $1000.00 3 years ago. Floor still looks great. I spilled brake fluid, coolant, trans fluid, and gas on the floor, just wipes up. Brake fluid sat over night, no problem. I used other products on the floor but they all kept comming up.
Whatever you do make the right choice from the beginning. I didn't and I had to get the old product off the floor before installing the U Coat It. Your floor is only as good as what it will bind too.
Old Jan 31, 2007 | 03:25 PM
2MuchRiceMakesMeSick's Avatar
nice lift
i bought one in the group purchase over in the for sale c5 section
