Which Heater Core
Old Jan 23, 2007 | 08:13 AM
spanishsilver's Avatar
spanishsilver
Default Which Heater Core
Which heater core should I go with? Ac/delco or NAPA I am looking for quality because this is a big job. Are the Napas just as good as the Delcos?
Old Jan 23, 2007 | 08:27 AM
GDaina's Avatar
GDaina
I took my old heater core to the radiator shop, they used my side tanks and recored it...cost me $35.00. Perfect fit..I had purchased the AC unit, and the fit was horrible, sent the core back.
Old Jan 23, 2007 | 08:39 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
In my limited experience with new heater cores, I find that generally the inlet and outlet tubes are poorly formed on ALL new heater cores. This stresses the core when installed. I ended up recoring my original Harrison unit locally and was happy with the results.
Old Jan 23, 2007 | 09:11 AM
spanishsilver
my tubes are gone. can they replace them also. thanks
Old Jan 23, 2007 | 10:31 AM
BBShark's Avatar
BBShark
By "gone" do you mean they have deteriorated to the point they cannot be reused or you don't have a heater core?
Old Jan 23, 2007 | 11:01 AM
Q's 68's Avatar
Q's 68
I bought a new core at NAPA. The tubes were not bent out enough to fit though the firewall. I took it to a local radiator shop and had them bend out the tubes to match the original heater core and then they reinforced the tubes. Went back in with no problems and runs great
Old Jan 23, 2007 | 11:44 AM
spanishsilver
No I kinked and bent them taking it out ouch:o
Old Jan 23, 2007 | 02:21 PM
spanishsilver
Ordered the original GM heater core. I will post a pic of the harrison I took out and the NAPA one I will be returning. Workmanship is like night and day.
Old Jan 23, 2007 | 03:24 PM
Q's 68's Avatar
Q's 68
I'm surprised. The heater core I got from Napa was of good quality and almost identical to my original Harrison I pulled. I had it reinforced and pressure tested before I went through the trouble of putting it in and everything checked out ok. Too bad we can't always get high-quality replacement parts consistently.
Old Jan 23, 2007 | 04:33 PM
spanishsilver
Default Heres the pics for comparison
Harrison original GM Core
NAPA made in Mexico Core looks almost like they were trying to plug leaks.
GM Core
NAPA Core broken fins
GM Core
GM Core $129.99
Napa Core $88.00
Peace of Mind PRICELESS
Old Jan 24, 2007 | 02:38 PM
spanishsilver
New cores on its way
To Which Heater Core
