Holley carb install ?
Old Jan 23, 2007 | 03:02 PM
Robertp535's Avatar
Robertp535
St. Jude Donor '12
Default Holley carb install ?
I am replacing my Holley carb on my 71 LT-1. Should I use a 1/4 in. heat shield gasket with a standard gasket ? It only has the standard gasket on it now. If so does anyone know where to get one. Thanks for any help. Bob
Old Jan 23, 2007 | 06:32 PM
marshrat99's Avatar
marshrat99
Unless you're having heat problems or need some extra clearance no need to bother with the spacer/heat shield. If you're still interested, I'm sure you can find one at Jegs or Summit.
Old Jan 23, 2007 | 07:18 PM
Robertp535's Avatar
Robertp535
St. Jude Donor '12
Thanks for the info. My car ran fine without it. I happened to see the insulator in the 71 assembly book, Just wondering if there was any advantages or disadvantages in installing one. Bob
Old Jan 23, 2007 | 08:13 PM
Kid Vette's Avatar
Kid Vette
I'm running an insulator. I think it helps keep the fuel from boiling over. I don't think there is a downside to using one.
Old Jan 23, 2007 | 08:19 PM
noonie's Avatar
noonie
I use them on all carbs.
I think LARS has them available.
Old Jan 23, 2007 | 09:54 PM
gullick65wi's Avatar
gullick65wi
I would use it. I used to have a Holley that would "whistle" when it got hot, until I put the insulator/spacer in.
To Holley carb install ?
