im starting a fresh motor build for my 1980 vette and want to know the best plug style straight or angle? i was looking to afr but it seems all there heads come angle?why? they said straights r custom order.my current setup is straight and they work with my headers. please explain pro and cons thanks
My understanding is that angle plug heads might have a slight performance advantage (but minimal). However, some type of headers don't work too well with angle plugs (i.e. Hooker sidepipe headers)...
Don't know if AFR's plug location is the same, but GM angle plug heads work fine with Hooker sidemounts.
That number 2 plug will be awfully close to the header pipe... I have ZZ4 heads on my yellow '68 and the #1 plug is way too close to the pipe.. It works but I'm not too comfortable about that.. I might go with shorty spark plugs..
my hooker side mounts worked fine and bolted streight into my 210 afr heads...instead, i had to heavily modify my new hooker headers for an undercarriage exhaust.
I have dart 215 angle plug heads with Hooker super comps. A couple of the plugs are pretty close but with the slip on high temp sleeves I have had no problems.
with all the wait time for afr i will probably go dart unless someone makes a good argument to wait. been batteling in my head about 383vs 406. tell me if im right 383=200cc 406=215cc generally speaking for limited street/strip.
My first 383 had Dart pro 1 215 CC with the optional 2.08/1.625 valves with the factory porting. They were actually 221 cc as I got them.
It was good running motor with a solid roller. Of course it need more so I upped the cam duration and installed the dart 227 cc heads. I'm still driving it today like that today with a 5 speed.
gkull, were do u suggest i look for factory port&polish models? i was not aware that was availible for the smaller heads. what rpms do u spin a 383 215cc motor?
