Nitrous question
Old Jan 24, 2007 | 05:25 PM
Gordonm's Avatar
Gordonm
Default Nitrous question
For all you guys running N20. Not the multi stage Godzilla N20 systems, an adjustable plate system of about 150 HP. Do you run an electric or can you get away with a mechanical pump. I have read that you get inconsistant fuel pressure at the nozzle due to the pumping action of the mech. pump. This can lean out the fuel side and ruin your day. Even if you maintain a constant 6 or 7 pounds is the pumping action going to hurt the Nitrous/fuel mix.
Old Jan 24, 2007 | 05:54 PM
Scott Marzahl's Avatar
Scott Marzahl
I always ran a Carter Hi Output mechanical fuel pump and never had a problem. I don't think you will see pulsations that would hurt anything.
If you run an orificed return "T" fitting, you are going to have a pretty constant fuel pressure.
Old Jan 24, 2007 | 05:55 PM
nastee383's Avatar
nastee383
I use a single CARTER electric pump. I've been up to 150 shot with no drop in pressure on the gauge.
Old Jan 24, 2007 | 05:59 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I use a 140 gph electric pump that delivers fuel at 18 - 20 psi and branch off the fuel for the nitrous at the regulator..
Old Jan 24, 2007 | 07:04 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Hey I resemble that remark
I know of a few guys running smaller shots with mech pumps..so far so good. I have no personal experience.
Old Jan 24, 2007 | 07:20 PM
Gordonm's Avatar
Gordonm
You were exactly who I was thinking of when I made that statement
Old Jan 24, 2007 | 07:27 PM
GrandSportC3
your fuel requirement really depends on your total horsepower.. If you know what total horsepower (including the nitrous) you are expecting, it can be calculated how many gph you will need to feed carb and nitrous..
How many HP does your engine have (at the crank)?
Another issue with a mechanical pump is that under heavier acceleration, you will lose pressure from the tank to the pump. My electric pump pumps at 18 - 20 psi. The acceleration will reduce the pressure but I still have plenty at the regulator..where I regulate it down to 6.5 - 7 psi...
Old Jan 24, 2007 | 07:39 PM
gyopp's Avatar
gyopp
I have not run mine yet but I used the mech pump, a fuel log with a return line out the back end, and a bypass type regulator mounted on the pass fenderwell right above the factory lines. My thinking was to use the volume of the log and return line to the regulator to smooth the pulses of the mech pump. Also, this setup with the bypass regulator should always keep cool fuel to the engine.
Old Jan 24, 2007 | 07:44 PM
Gordonm's Avatar
Gordonm
Yes I agree on this. My fuel pressure stayed rock steady at 6 psi from idle to 6200 rpm on the dyno but this was not moving. When the car is accelerating you most likely will see a drop. The engine builder who machines my motor said to use a electric at the tank and a mech at the motor to insure you will have plenty of fuel. I have not made a pass at the strip yet with the fuel pressure gauge hooked up.
I assume I am making in the neighborhood of 500 HP at the crank because I ran 409 HP at the rear wheels.
Old Jan 24, 2007 | 07:47 PM
GrandSportC3
If you are already at that horsepower level, I would not run a mechanical pump.. Get a electrical one!! You can pick up a new 140 gph pump for under $100 on ebay..
I'm still in the experimenting phase with my nitrous setup too but I'd definetely go with a electric pump at that horsepower level!!
Old Jan 24, 2007 | 07:59 PM
Gordonm's Avatar
Gordonm
Pretty much what I figured. I'd hate to melt the pistons due to lack of fuel pressure. Not sure if I will even run it but it sure looks tempting to pick up 100 to 150 HP at the touch of a button.
Old Jan 24, 2007 | 08:02 PM
GrandSportC3
Well, you can also install a fuel pressure switch that will shut off the nitrous if the fuel pressure drops.. That way you won't melt a piston... I wouldn't want to run nitrous without such switch!!
I also have a indicator light if the solenoids open up.. If they'd shut down due to lack of fuel pressure, I'd see the nitrous light turn off..
Old Jan 24, 2007 | 08:57 PM
gyopp's Avatar
gyopp
cheap insurance
Old Jan 24, 2007 | 09:14 PM
73jst4fun's Avatar
73jst4fun
What this s*%^... just what you need... what's next "Pinks"
To Nitrous question
