steering wheel
Old Jan 24, 2007 | 06:58 PM
Doug Maitlen's Avatar
Doug Maitlen
Default steering wheel
I have a telescoping steering wheel on my 79. The problem is that the steering wheel moves in and out with a simple push. What can I do to fix this?
Old Jan 24, 2007 | 07:30 PM
marshrat99's Avatar
marshrat99
This should be a simple fix if everything is still intact. Your 79 has a level on the wheel that you move in one direction to allow the column to move in & out. The other direction tightens. This level actually adjusts a small nut underneath the horn button. You'll have to disassemble the steering wheel until you get to the point of exposing the level and associated nut. Just run the nut in ever so slightly. "Ever so slightly" is just 1/8 or 1/4 turn ! You may have to play around a little to get it exactly where you want it.
Old Jan 24, 2007 | 07:42 PM
Duke94's Avatar
Duke94
Pull off the horn button, remove the 3 screws that hold the horn contact ring and remove. You should now have what you see in the picture below.
Now remove the 2 screws that hold the adjustment ring to the adjusting screw. Rotate the adjusting ring counter CW until the next holes line up with the holes in the adjusting screw and reinstall the screws. This will allow the adjusting ring to turn further CW to tighten the column.
Note also that there is a wealth of steering column info by Jim Shea at this site.
http://jimshea.corvettefaq.com/?page_id=4
Old Jan 26, 2007 | 02:33 AM
RIJVETTES's Avatar
RIJVETTES
thanx Duke94. good information.
To steering wheel
